#11 | |
![]() Join Date: Feb 2006
One other trick - I have the wife put her other big toe under the brake pedal so it does not go all the way to the floor. Somehow I feel better about not running the master cylinder plunger all the way to the end of its stroke.
#12 | |
http://www.zr1.net/forum/showthread....ht=soft+brakes |
#13 |
#14 |
Thanks for the feedback guys. I will try bleeding the brakes again this weekend. Hopefully that'sthe problem....
I went with a Valvoline DOT 3 & 4 Syntetic Brake Fluid. Any reason I should go with another brand? |
#15 |
#16 |
![]() Join Date: Feb 2011
$6 parts store DOT3 until you get the kinks worked out. A good dot3 flush is cheap-you can bleed in some premium stuff right before you go to the track.
#17 | |
The FSM bleed sequence is RF, RR, LR, LF - not the sequence I mentioned earlier. However --- there is a caution note in section 5E1 to never charge the battery with a quick charger with the negative battery cable connected. Failure to disconnect the negative cable could result in the BRAKE fuse to blow or serious damage to other electrical components. YIKES !!! How many AAA bozos know that requirement? How many ECMs have had their service life reduced by a quick charge? And who would look in section 5E1 for how to connect a quick charger? BEWARE ...
#18 | |
Please post root cause (and your impressions on the new pads, etc) when you have it all resolved Glenn |
#19 | |
![]() Possibly some re-shimming of the calipers to get them more perfectly centered would have helped that, I dunno. However, on your car, there is no reason it shouldn't feel as good or better than before you messed with it. Air in the line sounds like the most likely culprit. Also, can you explain your bleed procedure in more detail? Did you open the bleed screw, have your wife pump the pedal twice, then close it? That's sort of how it reads. Also, FYI, if you went to braided lines, watch the rear line. They don't have an angled exit from the caliper, and thus sit a lot closer to the edge of the rear wheel. Mine would tap-tap-tap on the wheel weight, until I loosely zip-tied it out of the way. I have to say, on the brakes, I wish I had just stopped after putting on HPS pads. That was more than good enough, and completely headache-free. I am trying to remember that lesson on the V, and resist the urge to upgrade to the 15" 6-pots from the new one... Last edited by Aurora40; 04-12-2011 at 08:16 AM. |
#20 |
Also, you could probably cycle the fluid in the ABS module by hammering the brakes in the rain. I never did anything to specifically bleed it.
