Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 04-30-2011   #11
Aurora40
Aurora40's Avatar
Default Re: April 30th, drag racing at Mason-Dixon!
Great day! Weather could have been a little warmer for traction, but it seemed like people were running faster and faster as the morning progressed.
Videos, all are available in 1080p:
Lightning and 'stang
Jim trapping 120
'stangs, one with I think a huge turbo
Infiniti that was quicker than I'd have thought
yellow C4
Rich running 12.8
5.0 vs SS
some more 'stangs
Sean nailing a 0.00 RT, and winning 3 dyno pulls
Sean's PB (I think)
Someone driving Jim's car, who we can only assume was Jim, running a 12.15, the fastest 'vette of the day
Bob Saveland
Former owner of #2517
Old 04-30-2011   #12
Aurora40
Aurora40's Avatar
Bob Saveland
Old 04-30-2011   #13
Aurora40
Aurora40's Avatar
Bob Saveland
Old 04-30-2011   #14
QB93Z
QB93Z's Avatar
You just can't do better than a day at the drag strip with your ZR-1 friends:
Here is Rich at the line:
Here is my black 1990 (please ignore the '93 wheels) comming off the line.
Thanks Bob for posting the videos. The best time was my son Roger driving the 1990. He got better on each run and his last run was a 12.15 at 121.94 mph. The 60' time was 2.050 sec, his best for the day.
My best time was a 12.48 at 118 mph. It was a real thrill to watch my son beat my best time, since I taught him everything I know. LOL.
The Quasar Blue was running poorly and the Tech 1 showed it very lean so we didn't get any good runs with it. I will have to continue investigating the fuel problem.
Thanks the the Mustang Club for letting us share that track with them.
Old 04-30-2011   #15
Aurora40
Aurora40's Avatar
Heheh, your secret was safe with us! Roger definitely was running better each time. I also noticed he seems to launch like Sean does. Instead of bringing up a steady RPM, he blips at the gas a few times, and goes on a blip.
It seems to result in pretty good 60' times that way, and no one can argue with the RT's it was producing! Perhaps I need to change my technique in the future.
Also, I believe you ran an identical 12.48 but at 120mph earlier. That 368 is definitely making some power. I believe Sean and Rich's high traps were around 112mph.
Bob Saveland
Old 04-30-2011   #16
QB93Z
QB93Z's Avatar
I think you are right, Bob, but I couldn't find the slip. It must still be in the car.
The big difference for Roger was moving from the left lane, that had a water box to the right lane where the ramp was dry. We believe that in order to use the water box to heat up the tires, a driver has to ensure that the tires are spinning as the car moves forward all of the way past any wet area. Other wise you end up at the line with wet tires.
I had trouble with the shifter in the 1990. It is stock and feels "sloppy" compared to the Hurst short throw shifter that is in the Quasar. I have proven that the "2nd-to-5th" shift technique does not give a good ET.
Old 04-30-2011   #17
QB93Z
QB93Z's Avatar
Also, Roger was shifting at a higher rpm than I did and for that 12.15 run he crossed the line in 3rd gear. The car has a stock 3.45:1 differential. Roger was shifting at >7000 on that run.
Old 04-30-2011   #18
Scrrem
Scrrem's Avatar
Bob,
Those are awsome! Thanks for shooting those videos! Had a great time guys. The Z ran great on the way home, so I guess I just overheated the disk.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 04-30-2011   #19
Damn guys
I'm jealous. Sorry I couldn't come, but looks like great fun!!!
Old 05-01-2011   #20
Scrrem
Scrrem's Avatar
Jim heating up the drag radials on the new 90!!!
Ron Davis Radiator
