#11 |
What works for me is to think of it as the ratio between base circle height v lobe height. If the base circle represents where the valve is closed, then the valve begins opening sooner, open longer and deeper with the regrind. The center of the base circle is moved closer towards the tip of the lobe. Having just had a larger intake installed, I can tell you it changes the bass note of the idle. You won't be balancing a nickel on the plenum anytime soon.
#12 |
#13 |
![]() Join Date: Mar 2007
At Pete's today, we confirmed that the regrind, which is about .025 to .030 ground off the stock cam, will allow me to use the new stock OEM replacement lifters, despite the valves being set in from 2 valve jobs. If Phil lets me, I will write an article on checking the lifter height to ensure that the cams do not hang the valves open.
#14 |
![]() Join Date: Dec 2003
Let you write an article???? I'm sure he would be very happy to have your contribution. I know you'll put some photos in there too!
#15 | |
![]() Join Date: Jan 2004
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
#16 |
Correct!
#17 |
Well that doesn't seem bad at all if the lifter does indeed have .060 of play like I have heard.
