Old 03-12-2011   #11
ammrpm
ammrpm's Avatar
Default Re: Plenum Pull: problems and questions
Well, after lots of struggling with the 2 broken bolts I was able to get them out. One of them I just had to drill out. Once enough material was removed with the drill I was able to pull it out. The other one I was able to work long enough with some PB blaster and vice grips that it started to move. Then I was able to unscrew it.
Now I can get back to checking all the rest of the vacuum lines and cleaning some stuff up.
I have ordered a bunch of stuff from Jerry's gaskets. I ordered some MSD coils from Jegs. I just need to order some injectors from FIC now. Can't wait to get this thing back together.
ammrpm is offline   Reply With Quote
Old 03-12-2011   #12
mike100
I just got done with mine and I used the Lucas injectors fromficonnection. It runs so much smoother and starts up right away now. You could tell it ran a touch rough on mine though- sometimes the dual mass flywheel even clattered.
4 of my injectors were bad (low ohms) and even missed when they got hot, but I would not necessarily toss your late model ones until you check them out.
Old 03-12-2011   #13
jrd1990zr1
jrd1990zr1's Avatar
Originally Posted by ammrpm View Post
Thanks for the responses!
I just bought this car about 2 months ago. I knew it had a vacuum leak under the plenum when I bought it so I knew I was going to pull the plenum after I got it.
It seems the lack of driving this car has caused its fair share of problems. So I am going to go ahead and replace the injectors, coils and plug wires while I have the plenum off. I will probably go ahead and have the plenum and I/H ported as well.
I am definitely going to give Jerry's gaskets some business. I will need lots of gaskets and seals for the plenum, I/H, coolant pipe, injectors. Looks like I will need some coolant pipe bolts as well.
As for the tightness of the bolts on the I/H... not all of them seemed that tight. This might have been part of the problem.
Now that the plenum is off I have been trying to run down the cause of the vacuum leak. I have hooked up my vacuum tool to the secondary vacuum reservoir. The reservoir won't hold a vacuum. It is not a quick drop on the gauge, but it does drop. I also checked the secondary control solenoid switch and it does the same thing, slow drop of vacuum. I checked the secondary actuators and those are both rock steady. They start to crack open at about 1 inhg and are fully open by 7 or 8. Does that sound right?
Where is a good source to find a secondary vacuum reservoir? Where can I find a secondary control solenoid?
Thanks!
Aaron
For the secondary reservoir if Jerry doesn't have one there is one on E-bay item # 250785691792.
Secondary control solenoids come up from time to time too. If Jerry doesn't have one and you can't wait try Kurt White.
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 03-12-2011   #14
ammrpm
ammrpm's Avatar
Thanks for the 'heads up' on the parts!
