Old 03-04-2011   #11
Aurora40
Aurora40's Avatar
Default Re: Muffler Bracket Bolts
Originally Posted by Scrrem View Post
The system I installed was pre-welded, so I don't have the luxury of loosening clamps and making the adjustment.
Is it just tacked? Or welded all the way around? Because using longer bolts and spacers seems like the wrong way to fix the problem, if you can just grind off the welding.
For the record, though, mine are shorter like Jim's, they don't have lots of extra thread like Phil's picture.
Bob Saveland
Former owner of #2517
Old 03-04-2011   #12
Scrrem
Scrrem's Avatar
Agreed Bob, one joint at the center of the pipe coming of the muffler is welded all the way around, the other's may just be taked need to check. I don't need a lot of space, I just want to get it away from the bumper cover.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
