02-22-2011 | #11 |
Re: O2 Sensor Plug
I went with the Bosch standard replacement O2 sensors by application. I could go dig up the part numbers, but they were just a standard replacement part. I got them at AutoZone, they were about $100.00 each.
Scott, You be Da Man. Sure I can put those to good use. Let me know the costs because this is stuff you could use on your car, and it ain't like the used stuff I've been sending the Brett! Straight up man, tell me what you want for the bolts and the P/W custom part. I am more than happy to buy this stuff from a Brother Z owner! Tom
02-22-2011 | #12 | |
Re: O2 Sensor Plug
Marc has already installed headers on my car so these are just taking up space. They're all yours! |
02-23-2011 | #13 |
Re: O2 Sensor Plug
Scott, Thank You!
You have a PM.
11-20-2011 | #14 |
Re: O2 Sensor Plug
I have this exact problem with the O2 extension harness from SW. Is there a way to reverse it?
Update...ordered Weather Pack Release tool from NAPA and will be swapping the pins around. Last edited by USAFPILOT; 11-20-2011 at 05:05 PM. |
