02-14-2011 | #11 |
Re: WAZOO DOES IT AGAIN>>
Hey Phil, thanks for the pictures! I don't know what it is about Fikse's, but they always look small in diameter. I'd have guessed those were 17"s.
Had you just jacked the car up when you took those? The rear looks cambered in.
02-14-2011 | #12 | |
No, it's still at the factory ride height and camber setup. The street surface angles some where it's parked which may be causing some distortion in the photo. But I must admit after seeing David's AB lowered with coilovers my Z appears to be riding a little high in the water by comparison. Both front and rear tires are 26" in diameter which are slightly taller than the original factory tires.
