01-09-2011 | #11 | |
Re: Interesting II...(Sorry Paul)
01-23-2011 | #12 |
I only wish....
Now here's a depressing part guys....I deal with Bullet to do all my custom grind cams. So I called them a few weeks ago to see if they did 4.6L Mod stuff, they said no prob. I just got them a couple days ago, under $1100.00 bucks! Sure isn't like this for our Zee's.....
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
01-23-2011 | #13 |
So.... did you talk to Bullet about maybe doing some LT-5 cams???
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
01-23-2011 | #14 |
Well of coarse I did buddy. A while ago already. They don't do, nor have ever done LT-5 cams. They know about them, but have no call or have ever had enough demand for them. Problem isn't actually grinding the cams, it's that they don't have or have access to the cores. That's the big deal. Not only with LT-5's, but other things as well. They just did a 60mm roller cam for a Mopar R-3 for me, that was almost 1K! Just one cam! Just because of the core.
01-23-2011 | #15 |
We had a little discussion about cam blanks at VanDorns BBQ at BG this last year. I heard that a contract option exists to run another batch of cam blanks, 300 units I think. If I recall correctly LPE holds the option. I'm a bit fuzzy on the details now and who exactly told me this... might have been Corey Henderson.
06-06-2011 | #16 |
Hey guys....Ssooo....I'm almost done this 4.6L Mod Motor project. I'm still not at all impressed....compared to our LT-5's. Pretty weak if you ask me. Too many chains, too many tensioners, too many followers, the non-moving hydraulic lifters are a joke. Not impressed at all.....
06-06-2011 | #17 |
06-06-2011 | #18 |
06-06-2011 | #19 |
06-06-2011 | #20 |
The new Coyote engine architecture will probably relegate the Modular engines to unpopular junkyard fodder. It's all about economy of scale and using the same powerplant across many models (trucks, mustangs, formerly the crown vics) just like GM has has done with the LS engine.
variable valve timing with future displacement increases will make the coyote engine the swap to do for older Fords. I never liked the modular 2v engines...they would blow a head gasket at 100 and some odd thousand miles and usually you just junked the car. LT5: too bad GM never had any shared use or they could have made these by the 10's of thousands yearly. |
