12-30-2010 | #11 | ||||
Re: HOB Re-Read
12-30-2010 | #12 |
Re: HOB Re-Read
Jerrys Gaskets: Banned list
Lee Gaffigan=Lifetime ban
12-30-2010 | #13 |
Re: HOB Re-Read
OK, OK, stop whining. You can come out of your room now.
12-30-2010 | #14 |
Re: HOB Re-Read
12-30-2010 | #15 |
Re: HOB Re-Read
Speaking of broken noses on cams...anything that can be done with those? I have 1....
12-30-2010 | #16 |
Re: HOB Re-Read
It was mentioned by a MM dyno operator that, and I quote
"3)Cam shaft failures....more to it than someone at the plant over revving the motor....there was nearly "0" clearance on the cams, creating an oiling issues...this was fixed....many of the spare motors floating around were the motors with cam clearance issues." Does this imply that the "crate" LT5's floating around that will have this problem? I ask simply because the MM LT5 program ended so much earlier than the actual Bowling Green ZR-1 program ended. Problems identified by actualy driving the car could not be solved on the LT5 assembly line, simply because that assembly line didnt exist anymore. I don't own a ZR-1, but I think that the LT5 is an excellent engine. peace Hog |
12-30-2010 | #17 |
Re: HOB Re-Read
No not crate engines, it was corrected early.....there were some of the test motors floating around that had the issue......many of them were fixed. I am also guessing that it was a case by case basis.
There was a guy with 10-11 of the motors, and they had the issue, as I understand it they were all corrected by someone. I believe the guy got these for free.
12-30-2010 | #18 | |
Re: HOB Re-Read
I'm not bashing. I should have put question marks in place of some of the periods. Ignorance breeds fear. When you guys type about the internals of an LT5....I sit up and take notes. This is a steep learning curve for me. Heck, I'm part of the choir and as far as I'm concerned I take great relish in pointing out that us ZR-1 owners are the only ones with a hand built motor in an American production car .....contrary to the hand assembled stuff you can get now. I'm not throwing rocks....well maybe small ones! ....but nothing about most the parts for an LT5 arrived at MM ready to assemble! grasshopper
12-31-2010 | #19 |
Re: HOB Re-Read
Well...... OK, but only if you promise to play nice.
12-31-2010 | #20 |
Re: HOB Re-Read
I promise!
Happy New Year guys!
