12-21-2010 | #11 |
Re: Some "Dynomite" Heads!
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 Last edited by Locobob; 12-21-2010 at 04:15 PM. |
12-21-2010 | #12 |
12-21-2010 | #13 |
The "boring" or the "not funny"??? Dont hurt my feelings now Carter
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
12-21-2010 | #14 |
It's all good. Just giving you a little pre Christmas "goose"
12-21-2010 | #15 |
Thanks for the starting info! Dynomite is getting good head . Locobob gave me a great education in porting & cleared up a lot of misinformation that I had., Dyno will be more than happy with the work. Keep this thread updated with you progress.
12-21-2010 | #16 |
Im paying down the Bottom half was home to get the set back together
12-21-2010 | #17 |
Well im confused I though this was machinst porn
12-27-2010 | #18 |
Got a little more time in on the heads. Currently I am still working on enlarging the primary intake ports and also matching them to the injector housings.
Here we have the bottom of the injector housing with the balsa wood template in place. I like to use this small dremel sander to trace around the ports - it is easy to control and allows me to precisely control any angle so as to get a proper representation of the top of the port. Same template only now applied to the head. I use this fine marker to trace the pattern onto the mating surface of the head. Same head now with the balsa template removed, you can see the red marker designating the area to be worked in order to match up the head ports with the injector housing ports. Generally I repeat this process 3 or 4 times until I am at the size I want and have a good match. A bit overkill... yeah probably but it helps to keep and eye on your work as you go - otherwise you can end up with mistakes that are hard to correct. Primary ports in these photos are 35mm at the mating surface and will end up being about 36mm when I am finished.
12-27-2010 | #19 |
Thing of beauty! Thanks for sharing, once I get the motor out of the 90, going to port the heads....first venture with head porting.
12-28-2010 | #20 |
This is my first start to finish head porting venture also Lee. It is nice having the set I reworked handy for reference.
