12-10-2010 | #11 | |
Re: WMD - Sunday, December 12th, in Westminster, MD
This stuff was a close as I could find to OEM sealer, worked pretty well. http://www.permatex.com/brand_right_stuff.htm Rich
12-10-2010 | #12 |
12-13-2010 | #13 |
It was a pretty crappy day yesterday, weatherwise, how did the WMD go? I was too afraid to drive up there in case the weather turned worse. They were calling for possible hail/snow.
12-13-2010 | #14 |
The weather was crappy. But, we accomplished a lot in a long day of wrench turning. I want to post an extreme thank you to Phil, Darrin, Yun, David, and Dennis for their invaluable help in accomplishing all of the jobs I wanted to get done.
We replaced all of the rear suspension bushings, replaced all U-joints, and ended up replacing the differential. I will post some pics a little later. What started out as a "simple" task to stop a very small leak from the differential, turned into a major replacement job. Upon disassembly, we discovered that the differential had been modified/replaced sometime in the past and that I had been running a 3.72:1 rear end ratio. In addition, the drive shaft connection to the differential had an old style, U-bolt to hold the U-joint so we had to replace the input shaft. With Phil's expertise, David's spare differential and a couple of trips to the auto parts store, we were able to return everything to stock. After a short test drive in the rain, I am very pleased with the results of all the work. The car runs and sounds better than it ever has. Thanks again for all the help. Jim Last edited by QB93Z; 12-13-2010 at 10:24 AM. Reason: I can't type right. |
12-13-2010 | #15 |
As promised here are some pics for Sunday's WMD:
Exhaust, C-Beam, and driveshaft removed, half shafts disconnected: Differential removed and disassembly underway: Batwing ready for new bushings: Pumpkin installed to the Batwing: Installing the rear spring: Installing the rear spring, passenger side: |
12-13-2010 | #16 |
Great pictures Jim, wish I could have been there.
Rich
12-14-2010 | #17 |
Nice Job! Glad you were able to get her all done. Z brotherhood at its best!
12-14-2010 | #18 |
Look's like a nice productive day for all ! Don't you just love it when a nice group get's together ? Would have really like to been there.
------------------------------------------------------------------ Why is David biting his lower lip in the pic's ? Didn't anyone feed him ? |
12-14-2010 | #19 |
12-14-2010 | #20 |
