12-13-2010 | #11 |
Re: Need Technical Data; cam timing, balancing, etc.
I have in my notes, from an old LPE catalog, that they also made a larger cam. 244 or 246 duration @ .050, and .454" lift. Anybody else heard of those? I've long since thrown the catalog away.
12-15-2010 | #12 | |
Jerry Aaron gaved me some time ago the following specs about his cams. Stage 1 .230 .230 .420 .420 Stage 2 .236 .236 .440 .440 Stage 3 .242 .242 .454 .454 I post in the next weeks a dyno sheet about my customers 427 with stage 3 cams. Sam |
12-15-2010 | #13 | |
I wonder if my data is wrong or if he may have modified the grind a bit. Looking forward to the 427 results!!
12-15-2010 | #14 | |
I measured the Stage II's from what i remember they are .237 no big deal for 1 or 2 degrees. Most tuners will say 1 or 2 degrees difference just so they are different from there competitors cam grind. It could be same cam and same manufacturer most customers don't check/measure cams. Pete
12-16-2010 | #15 |
True story. I measure every single cam(s) I install. Sometime the numbers can be surprising, right along the lines as what Pete mention's.
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
