12-19-2010 | #11 | |
Re: 18" CCW LM20s
Does the $1,500 include the tires?
Roger Miller 91 ZR-1 #391 |
12-25-2010 | #12 |
Re: 18" CCW LM20s
Same Question? Thinking about selling my Dymags (not cheap tho..)
H
02-16-2011 | #13 |
Re: 18" CCW LM20s
Bump.
06-23-2011 | #14 |
Re: 18" CCW LM20s
Bump.
Replaced the used 295/35 Goodyear F1 Supercars with new 275/35 BFG KDW2s. |
06-23-2011 | #15 |
Re: 18" CCW LM20s
Gorgeous wheels. Wish I could buy them but just too much going on right now.
GLWS
06-23-2011 | #16 |
Re: 18" CCW LM20s
scholtmj,
I noticed you mentioned having Brembos and they tended to push the wheel too far outward. I have Brembos on the Black Rose car and have noiced same issue but with ZO6 wheels. What is the issue with the Brembo and the offset? Any ideas? I'm thinking of ditching the Brembos and going with C6Z calipers on the front at least for the same reason. |
06-23-2011 | #17 | |
Re: 18" CCW LM20s
You can see the rotor hat has it's own hub-center which stuck out farther than the stock wheel hub. Last edited by scholtmj; 06-23-2011 at 02:53 PM. |
06-23-2011 | #18 |
Re: 18" CCW LM20s
scholtmj,
That's what I had suspected. I called Brembo and was told that there actually never was a brake kit for the C4 officially developed. The Brembo brakes on C4 were put together with "off the shelf" components of what worked. With stock C5 rotors on my previous ZR, the additional wheel offset was hardly noticeable. The Brembos have exaggerated that offset differential. I was also told that it wouldn't be possible to swap "hats" due to the positioning of the rotor relative to the caliper. Its my understanding that you could not swap in a stock C5 rotor in conjunction with the Brembo caliper. |
