Old 11-11-2010   #11
bldavis11
Default Re: headlight motor troubleshooting
you'll be good for quite some time! I ordered my bushing from Mid America as well. Tight fit!!
bldavis11 is offline   Reply With Quote
Old 11-12-2010   #12
Aurora40
Aurora40's Avatar
I am aware bushings go bad. However, I've never seen that happen where the motor didn't run at all. Rather it would run and not move the housing, or it would sort of rock the housing as it failed to move it.
So has anyone had this same behavior happening, or are you just saying "change the bushings" because they are known to go bad? Don't take it the wrong way, I appreciate the responses, but I'm not asking "what can go bad in headlights?". I'm asking if anyone has seen this particular behavior, or if anyone has ideas on how to troubleshoot it.
Bob Saveland
Former owner of #2517
Old 11-12-2010   #13
Bob its got to be the bushings or the motor may have bound. Either way the motor is going to have to be opened up to determine what has happened. My money would be on the bushings as well
Old 11-12-2010   #14
Wink Re: headlight motor troubleshooting
I will have to agree that the motor has to be opened up. I had the exact same symptoms, but at first had working light and just a little bit of noise after closing. Then when one stopped opening there was no noise, but then worked again later with noise. I just happened to go through the rebuild last week to find this:
I wondered how it even worked looking like this?
The other side was working fine but I thought not knowing the history I should just replace the bushings it while I'm at it to find this:
It was like WTF, Batman! Full of blue grease and rounded off steel nuts.
I had no idea or who or how long and even though they worked fine I did not like the idea of steel on plastic and replaced the bushing on this right side too. Everything is perfect now.
The Hillbilly's have moved to Hawaii Craig
Old 11-12-2010   #15
HAWAIIZR-1's Avatar
Bob,
As I stated, but did not articulate too well I had the exact symptoms where it did not work and no motor noise at all when it last failed. Not saying it is bushings but mine started with motor noise continuing after opening and closing, then not working at all with no motor noise.
Daryll,
Well, based on CARFAX.........my Z history started out in IL and moved to FL then I bought it from FL, so the hillbillies came from one those areas based on prior ownership. Neither one will claim they have hillbillies.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 11-12-2010   #16
xlr8nflorida
xlr8nflorida's Avatar
I'm saying replace the guts and I bet your motor is just fine.
Old 11-12-2010   #17
Hmm im hearing Banjos from Florida and Illionis LOL
Old 11-12-2010   #18
HAWAIIZR-1's Avatar
Daryll,
You peaked my interest so I had to look at my old docs. The only known owners I tried to track down is Chris Molenda from Palatine, IL and Seth Morris from Palm Harbor, FL. Other registration shows Odessa, FL but some of the old timers may know the names.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
