09-20-2010 | #11 |
Re: No power; No check engine
Great idea! I will hunt some down. Thanks .
1991 ZR1, White/Red. |
09-25-2010 | #12 |
TFENT
I see you found your problem hope you find the part needed to get you going again. I found my problem. As suspected I have crossed two of the plug wires. The #3 and #5 wires were switched. Once I corrected it the motor runs great. I also found my oil leak it was from the pcv valve holder. I was able to repair it. Thanks for everyones input.
09-25-2010 | #13 |
if you buy msd wires for our cars it come with the little clips that go over the wires so you can mark the cylinder. i one time crossed the last 2 cylinders on the passenger side of the car and it acted as you say yours does , dont know if thats it for sure ,but you might want to give it a try.
