Old 09-06-2010   #11
rogerzr1
rogerzr1's Avatar
Default Re: Service ride control light
Tom,
Thanks for your help. Leave it to me to come up with something no one has ever seen before. I will see what I can find out with the grounds.
Roger
rogerzr1 is offline   Reply With Quote
Old 09-07-2010   #12
Roger, we ain't dunn yet!
Let me bounce something off you, bear with me because I'm slow on the uptake with this electronic stuff...analog man as in cro-magnum man!
Is it possible moisture has invaded the master connector at the SRC module? I ask because all this stuff, the codes, looks like stuff that is transmitted on a serial data line....well to me it looks that way I'm figuring that the data "in" and the code data "out" has to go thru the same main connector.
Anyway, my simpleton move would be to go discon the SRC connector and check it for anything like water droplets/moisture?
Reasoning behind my suggestion is that my car sleeps in an unheated garage that is at/below grade in a co-op building and it gets like a meat locker in the winter. The humidity is off the chart sometimes and every spring I pull apart a few connectors and if I find water droplets got past the rubber gaskets; I then go on to do every one I can get to without taking apart the car.
