Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Prototypes
Old 06-10-2010   #11
Eric870
Eric870's Avatar
Default Re: 1989 ZR-1 #058 LT5 is liberated!
One more question. Any idea were this motor been for the last 20+ years? Did an 89 get scraped recently?
Eric870 is offline   Reply With Quote
Old 06-10-2010   #12
1989ZR1#74
It was at a scrap yard in the Detroit area for many many years. Been told it was 15+. The yard went out of business and the ebay seller bought it and all of their other engines. I was told the original scrap yard did contract work for GM destroying cars. I think #058 met its demise in the 90s. (but I am chasing that info down!)
1989 ZR-1 #04 Pilot, Advertising/PR Campbell-Ewald S9YKH1
1989 ZR-1 #58 LT5 only
1989 ZR-1 #74 Unreleased Production / PR Dept 9PR110
NCRS #3,182 SACC #2,420
Member Corvette Museum
Corvette Forum: "ewjxn"
2009, 2010 Gathering Attendee
1989ZR1#74 is offline   Reply With Quote
Old 06-10-2010   #13
Eric870
Eric870's Avatar
Originally Posted by 1989ZR1#74 View Post
Eric, I told everyone there they could own this 89 LT5 didn't I? I waited until the last day of the listing before I pulled the trigger! It has been up there for over 4 months.
Before 1990 production motors started, MM would stamp the assembly date and an overall sequence number on the oil pan boss. When 1990 began they did a date based sequence. So if an LT5 was made on the 1st of June it would have a sequnce specific to the 1st of June. on the 2nd of June they would start at #01 again. So 375 means it was the 375th LT5 built at MM before the 1990 model year LT5s.
THe build "assembly" date as seen in the photo is 12/20/1988
I will go over this LT5 and see what I can see. I need to make sure it's a runner. There are lots of little changes between the two. I will try to post them here as I can show them... Stay tuned! Eric
So what are the motor #'s for #4 and #74? Any idea how meny Preproductions LT5 there were?
Old 06-11-2010   #14
1989ZR1#74
#004 is MM 0418 CZA 218
#074 is MM 0308 CZA 612
Hard to believe that there were 237 engines made between #58 and #74... Have to find out why. Based on build sheet Bowling Green sequence numbers 7 to 10 ZR-1s were built after #074
Eric
Old 06-11-2010   #15
1989ZR1#74
I posted this in the MM number thread, but will repeat it here:
Update on 1989 MM numbers:
#026 is MM 0514 CZA 230
#029 is MM 0421 CZA 223
#045 is MM 1020 CZA 352
#058 is MM 1220 CZA 375
#062 is MM 1216 CZA 373
