Old 07-16-2013   #11
Default Re: Clutch Slave Cyclinder
I've been using Ranger's method of replacing hyd clutch fluid. Suck out old fluid w turkey baster, clean out master and pour in new fluid. Pump, then check to see if any dark or black fluid comes up. Remove that again, replacing w fresh fluid. Pump again. Repeat process till pumping only produces clear fluid. You're done.
