#11 |
from all the posts I have read about this issue it almost seems it will be in my best interest to machine myself a new fork. Those things look flimsy as heck, then add a upgraded pp on top of it and it looks like you have a recipe for disaster
#12 |
![]() Join Date: Aug 2008
I think it was already bent like that before I bought it. Because I always noticed that compared to all of my freinds Z's that I've driven my clutch would engage only about 2" off the floor board where as all my freinds Z's would have to let the clutch peddle out at least 50% before they would engage. Now that I put the new fork in mine engages just like everybody elses. I'm still getting use to how far I have to let the peddle out before engagement happens. That Clutch I bought is bad azz. When I want to shift nice and easy it does. When I want to shift fast it grabs with authority and doesn't let go. Spec recommends that I break the clutch in for at least 500 miles before I really romp on it. I highly recommend the Stage 3+ Spec clutch kit.
#13 |
![]() Join Date: Dec 2004
Rick thanks for the insights!
![]() I'll have to put the symptoms about the engagement point on the BOLO list of strange clutch behavior! Good luck with the new clutch set up! ![]() Tom
