Old 05-16-2010   #11
Default Re: DRM Coilovers, Wow why the hell did I wait ?
Old 05-16-2010   #12
Old 05-16-2010   #13
Old 05-16-2010   #14
Default Re: DRM Coilovers,PICS ! Wow why the hell did I wait ?
Ok Heres what was done supension wise.
Total Poly Body bushing kit (Prophane kit)
Poly Sway bar links and end links etc etc
Guldstrand Front Sway bar relocation kit (Carter200 makes these as well)
Upper and Lower Ball joints (moog)
DRM Front coilovers with Hyper Coils 425 Spring rate fronts
DRM Rear coilovers with Hyper coils 275 Spring rate rears
Rear dog bones replaced with Heim joint links.
Car handles well with stability, Does not wander. Very satisfied with the result. And no FX-3 lights. This build is solid.
Old 05-17-2010   #15
scholtmj
scholtmj's Avatar
Wow, looks great!
Did you have the rod end trailing arms on before or are these new? What's the ride quality like with rod ends instead of poly bushings?
Old 05-17-2010   #16
Aurora40
Aurora40's Avatar
They look a lot better on your car than they did in my basement! That front block is interesting for relocating the swaybar. I don't get how you use the stock end link though? Does moving the bar pull the end link back? It still looks vertical. Though obviously it all fit!
I always wonder why the ride seems transformed when people go to coilovers. Is it the OEM spring is fatigued? Is it the spring rates that are more equal front to rear? (usually people go to a softer front and similar or slightly firmer rear) Is it the reduced anti-roll rate?
It seems odd that steel providing the force vs fiberglass can make such a difference, but it seems everyone who installs them is more than pleased at the ride. There's no arguing the result.
Bob Saveland
Former owner of #2517
Old 05-17-2010   #17
Originally Posted by scholtmj View Post
Wow, looks great!
These are new. After pressing the poly bushings into the dogbones there was a clearance issue. I did not want to shave the poly bushing down, So.... the solution was to upgrade to the stronger Heim joints. Im sure it helps the car as it has never rode this well before. Guldstand has these listed on his website as well as a suspension upgrade. Must be something to it.
I have a complete set of dogbones loaded with the poly bushings now in my parts bin. LOL
Old 05-17-2010   #18
Thanks Bob All I know is they move the set up backward a bit to allow for the fit. The ZF doc had to shave the bushings a little to allow for clearance of the Thermostat housing. The new poly bushings are a bit too fat. Its got to be the roll rate is reduced I am very impressed with the DRM setup I did not beleive it would improve the ride this much but it does. I beleive the front and rear fiberglass springs fatigue with time and age. Some members have seen cracking and spliting on some very low mileage cars my front and rear fiberglass springs look fine. I feel its possible for these to develop memory. They also conform to body weight of the driver and such. Dont know It just works
Old 05-17-2010   #19
Me likey
Old 05-17-2010   #20
Originally Posted by FU2 View Post
Me likey
Thanks Frank
