Old 04-25-2010   #11
Sgreg
Sgreg's Avatar
Default Re: F/S SGS Stage III Cams $2000.00
Originally Posted by Pete View Post
Thanks Kevin
Moo Powah for the little 350, i hope
It will have to wait after BG.
Pete
Pete, you are the cam guy, but aren't you going to kill torque and low/mid range performance with a stage III cam set-up and ONLY 350 cubes ? I thought big cams were for strokers.
Sgreg is offline   Reply With Quote
Old 04-26-2010   #12
Pete
Pete's Avatar
Well here is my theory and research..
I know a smaller exhaust cam helps for low end power.
I will not be installing the Stage III exhaust cams instead i will go with smaller exhaust cams.
Another factor is cam timing.
I will find out what happens it won't be the first time i take my motor out for trial & error.
Worse case i will have to pull the motor back out to put the smaller cams back in or Stage III intakes make more power and stay in.
Basicly if i loose 10rwtq at low RPM but gain 20 on the big end they are staying in,right now i make around 340 RWTQ @ 3k rpm if it drops to 330 @ 3k and gains 20 RWHP at 6900rpm i can live with that
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-26-2010   #13
scholtmj
scholtmj's Avatar
Are you going to regrind the exhaust cams or put your current intake cams on the exhaust side?
Old 04-26-2010   #14
Pete
Pete's Avatar
I would not go any bigger then .230 exhaust cam with a .242 intake.
My Intake cams are .236.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-26-2010   #15
tpepmeie
Pete
Pete, i agree, 12 to 15 degree split is about what is called for with our port characteristics. Are all the Stage 3's really 242? I thought some of the LPE stage 3's were 239 duration/.445 lift.
Old 04-26-2010   #16
Pete
Pete's Avatar
Todd,you trying to give me a heart attack.
I thought SGC Stage III's were all .242 .450
LPE's Stage III/C cams were .239 .445
I always check my cams before install.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-26-2010   #17
tpepmeie
Pete
Sorry, man. I didn't even see SGC in the thread title. Was focused in on Stage III. I agree with what you posted, that's how I remember it.
Todd
