Old 04-07-2010   #11
rkreigh
Default Re: 1/4 mile launching techniques?
you want the weight transfer but the c4 independent rear doesn't maintian the best camber to keep the full tire plated when it squats
I worre the inside edges of the gy run flats out pretty quickly at bg making runs.
a flexibly sidewal tire takes the dump of the clutch and wraps up the tire more and will plant "at non optimal camber" angles must better
the really high power cars are a bit squirley, and the c beam flexes unloading one tire more than the other from the diff twisting
hook hard and roll on the throttle rather than dumping the clutch has been the only think that works which infolves slipping the clutch and then putting it to the floor after the 60 ft. eve then sometimes it breaks loose
with the hoosiers, I can come out hard! hope to see a 1.6 and not break anyting with a more talented clutch foot
f1s are lousy drag tires, don't like em on the street either. they handle well but don't hook up even with the 325 c6 size
95 390 LPE ZR1 (505 rwhp)
Old 04-07-2010   #12
Ron,
I guess I get to try the 19" 325s and see. I have found that Performance works better for launch. Mine has the Marracca valved shocks. Any thoughts on launch with lowered rear?
Old 04-08-2010   #13
jonszr1
jonszr1's Avatar
on my white 92 which is about 11/2 in lower than standard but also has coilovers .i lowered the bump stop on each side so that the half shafts didnt go into the negative angle as bill told me thats a good way to break things . i use the middle setting on the fx3. i am still getting used to the new nitto drag tires (nto5r) they show great promise though. its looking that 26-24 are going to be the best pressures to run with these tires and leave around 3500
Old 04-08-2010   #14
rkreigh
setting up the car for the digs involved some real compromise for handling
in essence, you can have a good drag car, or a car that handles
the FX3 can be setup with the custom controller (removable control chip) to allow front shocks soft and rear stiff to allow weight transfer, but not too much squat. I like the limiting idea on the bump stops, and also unbolting the front sway bar end links helps "free up" the travel
don't even bother on the supercar F1s, the sidewalls are rock hard and really only a good drag radial is worth going out there. street tires just don't cut it unless you really finesse the throttle and clutch
those NT05Rs look really good, but the 19' small sidewall hurts the launch as you want a "tall" tire with a deeper sidewall give to allow the rear tires to bite, but certainly they are going to hook pretty well
really a slick is what you need, but the zr-1 spindles and half shafts are "vulernable" when launching hard and hooking
great thread, Pete, where are you buddy
pete, haibeck, and my buddy phil can drive pick up several tenths on me anyday. practice and the nut behind the wheel make a huge difference
Old 04-08-2010   #15
jonszr1
jonszr1's Avatar
where can one get a custom controller????
Old 04-10-2010   #16
I appreciate your (all others too) comments. Is your launch at 3500 is with a light weight (Al?) FW, right?
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 04-10-2010   #17
jonszr1
jonszr1's Avatar
yes, its 3500 with the mickeys , i just got off the phone with the nitto guys and found out i should try going to 27-30 lbs and try going up 500 rpm .which i will do tomarrow at the summit series race at famoso, during the practice runs . if you are going to use street tires and a fidanza flywheel i would suggest starting off around 2000 and step up from there in 200 rpm incraments . get a legal pad and keep good notes of each run . i fo that and use a gtech pro rr that has a download program that shows wheel spin, exact shift rpm, length of time it takes me to shift.plus a bunch more stuff. it also has a shift light . i really like it . plus you can use it off the strip ifyou want to try something away from the track.hope this helps
