Old 05-22-2010   #11
limey
Default Re: Potential Sources for New Lifters
We sell brand new GM lifters for $16.99 each, or $499.99 per set of 32, that's a fantastic price for 32 OEM lifters.
limey is offline   Reply With Quote
Old 05-22-2010   #12
HAWAIIZR-1's Avatar
Thanks Kurt, I'll consider it in my quest for lifters. Your site listed them at $34.20 each so I started looking for other options.
I thought you sold the HT-2236 Sealer Power at one time too?
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 05-22-2010   #13
todesengel
I guess I am a little confused by the lifter deal.
While I understand the benefits of lighter and/or shim under bucket, why is there such a issue with stock replacement? Having rebuilt many dohc motors, the only time these were replaced were if there was a wear issue, and different sized shims were required to meet factory specs.
Do people do a full replacement with a rebuild on these things as a precautionary?
todesengel is offline   Reply With Quote
Old 05-22-2010   #14
Jagdpanzer
Jagdpanzer's Avatar
I my case I purchased a set heads that did not come with lifters.
I'm sure for most applications the standard GM supplied lifters will do just fine.
Old 05-22-2010   #15
HAWAIIZR-1's Avatar
In my case I am rebuilding my motor that had 53K miles and not sure I want to put the old lifters back in even though it would probably be okay. I am going to do Stage I regrinds so I thought I should put in new lifters. I'm still not sure since there are LT5 with over 100K miles and no issues with lifters or at least I have not heard a lot of issues with lifter failures, but will do more research. I really hate to put it all back together and in a year or somerwhere down the road have to replace some failed lifters; this is not a standard SBC and a big deal to me. My other concern was replacing with aftermarket as Sealed Power appears to be made in China and not sure about the quality, but where are GM lifters made? Sealed Power is a very reputable company so I would imagine some strict standards are being held with their name on the line.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 05-22-2010   #16
Pete
Pete's Avatar
Rob, no need to change lifters hey i know someone who had stock 60k mile lifters went with regrind cams back to stock cams back to a different set of regrinds with same used lifters now he has Sealed Power no issues.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 05-22-2010   #17
todesengel
Thanks. I just couldn't wrap my mind around why someone would change them if they were within spec.
Pete
Old 05-22-2010   #18
cvette
Stranger things have and do happen!!!!!!!!!!!!!!!
cvette is offline   Reply With Quote
Old 05-22-2010   #19
todesengel
I have already met Keith, no need to explain........
