Old 03-23-2010   #11
Hammer
Hammer's Avatar
Default Re: Clutch Replacement Issues
Glad to hear you got it back together John. Finish getting it ready to drive to BG.
4.10's middle of April and it's ready. I'll start packing tools and parts soon.
Old 03-23-2010   #12
Nice post up John
Old 03-23-2010   #13
flyin ryan
flyin ryan's Avatar
Nice post up John
Newsletter material....
Old 03-23-2010   #14
Originally Posted by Hammer View Post
30 ft-lbs for the 3/8-16 X 2-1/8 inch grade 8 bolts (pressure plate to Aluminum flywheel). I remember this because it's so low. Had to recheck to make sure I had the torque right. Metal bolts to aluminum flywheel. No loctite.
Hmmm??? The Service Manual Supplement suggests Loctite 262 Red on almost everything that you do not remove from time to time. Most of that stuff is Aluminum. For those items that you might remove from time to time (water pump, plenum for example) use Loctite 242 Blue
There are some stainless steel bolt kits and apparently stainless steel bolts in aluminum is subjected to galling. Some use anti-sieze on those fasteners.
I also see in this manual (I assume this applies for the flywheel bolts regardless if the flywheel is aluminum or steel) that the torque for Flywheel Bolts (7/16-20 x 1 1/4 inch Grade 8 bolts Aluminum flywheel to crank shaft) is 66 ft-lbs
Old 03-24-2010   #15
Hammer
Hammer's Avatar
Talking Re: Clutch Replacement Issues
I sent it to Dwight already.
Old 03-24-2010   #16
Hammer
Hammer's Avatar
I didn't see in the manual where it said anything about aluminum flywheels. I didn't look in the LT5 manual though, just the standard one. There was a recommendation for red loctite on the flywheel bolts and nothing for any of the other bolts. I wouldn't put anything on the clutch to flywheel bolts and there didn't appear to be any on the bolts when I took them out.
Old 03-25-2010   #17
flyin ryan
flyin ryan's Avatar
Wink Re: Clutch Replacement Issues
Awesome buddy .
