03-28-2010 | #11 | |
Re: TB coolant crossover,any disadvantages?
03-28-2010 | #12 |
after i did this mod .i took 2 3 ft sections of hose and ran 1 to the front air dam and the other tothe right side wheel well so that cool air can circulate thru the throttle body, dont really know if it helped ,but figured it couldnt hurt
03-28-2010 | #13 |
Coolest thing you could do for your throttle body is to install one of the Billet trottle body plates
03-28-2010 | #14 | |
Rich
03-28-2010 | #15 |
Rich,
Glad I could help
03-30-2010 | #16 | |
TIA Tom
03-30-2010 | #17 |
You should be able to buy heater hose that is that size. I suspect fuel hose would work too, though?
03-30-2010 | #18 |
Thanks Bob.....sometimes it's the simple things that escape my eye!
03-30-2010 | #19 |
I used fuel hose on mine................
04-10-2010 | #20 |
Got the job done,what a pain in the a$$.Despite the fact that this pipe was supposed to go in with out removing the plenum,that wasnt the case.There was no way in hell this was going in without at least raising the front of the plenum.Then I had to take my tube bender and change the pipe quite a bit on the driver side.Once I got the plenum up I could see oil residue everywhere so I went ahead and removed the plenum to clean everything up.While I had everything apart I found the secondary solenoid wasnt holding vacuum.In the past the pump would evacuate the system and cycle one second every 7 seconds then it got down to about 4 seconds.Replaced the solenoid no it holds vacuum for maybe 30 seconds or longer.The cars got a stumble if you stab the pedal off idle.Found a vacuum leak at the PCV fittings so Im working on that now.I ran a preformed hose off of the TB nipple to give it a finished look.[IMG][/IMG][IMG][/IMG]
