#11 |
![]() Join Date: Mar 2007
I did BP blaster with no success......MAPP Gas torch also. Time to cut to SOB off....plenty of thread to play with
#12 |
![]() Join Date: Aug 2006
Lucky you've got lots of thread...Still a PIA though
#13 |
![]() Join Date: Jul 2007
which bolt on the header? is it easy to get to?
#14 |
Yes, its D/S and right in the center, decent access from the side of the car.
#15 |
![]() Join Date: Jan 2007
This is probably too late in your case but one trick I learned from My Military days is try to tighten first before trying to loosen. The theory here is that the best flats on the bolt are on the tighten side and all you need to do is break the bolt loose which is what you are trying to do prior to loosing it. I have also seen a brass drift used to tap on the top of the bolt head to break the siezure. Not hard but a firm tap.
Good luck! |
#16 | |
![]() Join Date: Dec 2003
If it's the screw next to the center stud, worst case just don't cut it flush for now and don't put a screw there. I only do criss/cross pattern on my headers 2 screws on each header tube one the center stud tubes i don't even put screws the stud does just fine on the inner side and just put one screw on the outside of the center tubes. I can explain a little beter on the phone Pete
#17 |
Some thing like this Pete???
O= bolt, X= no Bolt (_ used for alignment) O____X__X____O___O____X__X____O X____O__O____X_O_X____O__O____X but think might be better: X____O__X____O___O____X__O____X O____X__O____X_O_X____O__X____O
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Flowmaster Cats - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Shelby Series 1 - Wilwood Brakes Custom Interior NCM Lifetime Member #978 Last edited by -=Jeff=-; 03-01-2010 at 12:24 PM. |
#18 | |
O____O__O____O____O____O__O____O O____X__O____X_S__X____O__X_____O This is my headers no issues Pete
#19 |
O= bolt, X= no Bolt, S= Center Stud (_ used for alignment)
O____X_O____X___X____O_X_____O X____O_X____X_S_X____X_O_____X I have also used this way with no issues. This is the way i was trying to explain to Lee. The reason i do it like my previous post is visaul all top screws are in and people stop telling me i'm missing screws, my reply "my wife thinks the same" LOL Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 03-01-2010 at 01:01 PM. |
#20 |
So....this is a bolt installed in a header, not the original exhaust manifold.
Then this bolt must be only about 3/8 inch showing after you grind off the head (maybe a bit more with the gasket). Pete's idea of just grind it off sounds like something I would do ![]() After I applied a little heat and vice grips but not too much heat ![]() I did not fill every header fastener position with a bolt either ![]() Last edited by Dynomite; 03-01-2010 at 06:12 PM. |
