Go Back   ZR-1 Net Registry Forums > General > ZR-1 Net Registry Club News
Old 03-04-2010   #1
93RubyZ
93RubyZ's Avatar
Default Re: VIN's Exposed - Thanks Guys
Yes, very nice! Thanks guys!!
Not to sound unappreciative, but I did want to point out one error I found in case it hasn't been noticed yet. There are a number of 1990 cars that are listed as Ruby Red. Maybe they were supposed to be Dark Red Metallic instead??
93RubyZ is offline   Reply With Quote
Old 03-05-2010   #2
QB93Z
QB93Z's Avatar
I do not see any 1990 cars listed as Ruby Red. Can you give me the car #'s or more specifics about which list you saw them on.
Thanks,
Old 03-05-2010   #3
93RubyZ
93RubyZ's Avatar
Thanks,
I think this is where I was looking:
http://www.zr1netregistry.com/member...lor_number.htm
But I seem to be getting an error now when I search. Searching for 68U, I now get the following:
Option 68U
This option was found on 426 cars
Description:
EXTERIOR COLOR,PRIMARY (68U)
EXTERIOR COLOR,PRIMARY,BRILLIANT RED MET (68U)
EXTERIOR COLOR,PRIMARY,DARK SADDLE METALLIC (68U)
EXTERIOR COLOR,PRIMARY,RUBY RED METALLIC (68U)
Back
Old 03-05-2010   #4
Jeffvette
Thanks,
Jim, search the DB, enter 1990 for year, and ruby red for the color, I get 181 results.
181 cars have these options:
1990 1G1YZ23J2L5800033 Show 1990 1G1YZ23J4L5800101 Show 1990 1G1YZ23J6L5800102 Show 1990 1G1YZ23J5L5800138 Show 1990 1G1YZ23JXL5800149 Show
When you search for Dark Red Metallic cars, there are none.
Old 03-05-2010   #5
QB93Z
QB93Z's Avatar
A HAH, The problem is that GM used the same RPO for different colors in different years, and different RPO's for the same color in different years.
68U was Brilliant Red Metallic in 1990 (marketed as Dark Red Metallic) and in 1993 68U was the code for Ruby Red.
In 1991 to 1995, Brilliant Red Metallic (Dark Red Metallic) was RPO 75U.
Another example is Competition Yellow. In 1990 and 1993-1995, the RPO was 53U. In 1991-1992, the RPO was 35U.
Old 03-05-2010   #6
Aurora40
Aurora40's Avatar
If you click the cars, they genuinely have that RPO.
GM used 68U for Dark Red Metallic in 1990. In 1991, DRM became 75U. They used 68U again in 1993 for Ruby Red. I can update the color description to have both, but that's how GM did it.
Would you want to see two colors listed, one the 1990 DRM, and one Ruby Red? It seems odd to me since it's an RPO search, but if that logically makes sense to people, I could do it.
Old 03-05-2010   #7
Aurora40
Aurora40's Avatar
My philosophy with the yellows was to honor GM's RPO organization. So two yellows are listed, yellow and comp yellow. With the exception of the roof panels, everything is that way (1990 roof options are moronic).
I can change the colors to be separate items if that is how it makes sense to others. Personally I prefer the RPO-based approach, but it's no big deal either way.
Old 03-05-2010   #8
Aurora40
Aurora40's Avatar
Also, and I think I speak for Jim as well, I want to say "thanks" for the feedback. There's an awful lot of data surrounding ~7,000 cars, each with about 40 RPOs on average, so it's hard to check everything. Getting feedback is helpful, plus it also means people are using the tools.
Good morning Bob, I guess we were typing at the same time.
You gotta get up pretty early in the morning to outsmart me!
Old 03-06-2010   #9
93RubyZ
93RubyZ's Avatar
Thanks for the clarifications! So if want to buy touch-up paint, and use 68U as the paint code, I may actually be getting the wrong color? That's good to know and means I need to make sure I'm getting 68U for the right year.
Old 03-06-2010   #10
QB93Z
QB93Z's Avatar
That will never happen!
