Old 02-04-2010   #11
secondchance
Default Re: Rear Suspension Pictures
Originally Posted by tomtom72 View Post
Okay I think I'm stating the obvious but I'll write this any way....
The Toe rod system(?) center of diff mounting to the lower knuckle is a ball joint, well sort of as it uses the same mechanical principals. If you have ever manipulated a ball joint going bad you have felt that it's not smooth, rather it feels notchy as it is moved in the socket. If you drive the studs out of the Knuckle and manipulate them they will either feel smooth and tight or loose and notchy. If they are dry then you could also expect noise something akin to the noise that a shot A-arm bushing makes...that annoying squeaking as the arm actuates over bumps in the road. You didn't describe the noise, high pitched squeaking (rust related) or a bass sounding clunking ( eroded ball & socket with too much end play in the vertical plane ) or snapping sound?
If the boots are cracked then the lube will have all run out and the joint is N/G. It will have rusted, or eroded or both. Too bad we can't lube them up at intervals.
Okay that's my two cents on the situation....
Noise I am getting occurs when rear wheels move up suddenly over a pothole (sometimes) or in rapid succession (more likely to induce noise). Left to right ocillation of rear due to bumps causes noise also.
Noise sounds sort of like popping - not squeaking.
Like Marc suggested, I think I will try jacking up the leaf spring, release tension and yank on various suspension members.
Old 02-04-2010   #12
RICKYRJ1
RICKYRJ1's Avatar
I can't tell youwhat the noise is but I can tell you mine are POLISHED and don't make any noise
Old 02-04-2010   #13
gbrtng
gbrtng's Avatar
Earlier C4s had grease zerk fittings at the outer rear tie rod end. I can't remember if the inner ones were greasable, but you should be able to find the earlier replacements.
Old 02-04-2010   #14
secondchance
Polished, eh? Why you suspension polisher!
I will track this down. Just repace a piece by piece if worst come to worse. I figure it's about time to replace these bushings and joints anyway.
Old 02-04-2010   #15
rhipsher
rhipsher's Avatar
Originally Posted by Scrrem View Post
Here's some from a 70K mile'r
Rich
Now I see on your 90 you have solid/stock camber braces. My 90 has adjustable ones just like the tie rods that you can adjust the camber in or out. I was told that they are after market and were not stock.
Old 02-11-2010   #16
Jeffvette
Yun, check your shock bushings. Uppers mainly.
