Old 09-23-2016   #11
Racinfan83
Default Re: Jump Starting
Jason just get a battery tender. I have used this one for 2 years now and it is great. You can probably get one online cheaper if cost is an issue...
http://www.sears.com/diehard-micropr...g&gclsrc=aw.ds
[LEFT][SIGPIC][/SIGPIC][/LEFT]
[CENTER][COLOR=Indigo][SIZE=4][I][B] **Now Sold** 1990 ZR-1 #2093, Black on Black..[/B][/I][/SIZE][/COLOR][/CENTER]
Old 09-23-2016   #12
lfalzarano
Thanks Racinfan83. I already have a battery tender.
Since I don't carry the battery tender on the road, I was trying to find the proper point to connect the negative ground jumper cable for a roadside assistance. The same holds true for the Jump N Carry unit.
Old 09-23-2016   #13
Connect jumper cable to Negative Battery Terminal and Positive Battery Terminal.
I do not use battery tenders......I use Battery Disconnect on ALL Zs.
Starter, Starter Relay, Wiring Harness, Battery, and Plugs Tricks
Old 09-24-2016   #14
lfalzarano
Thanks for the quick response. That was my thought also. My hesitation has been with the warnings in the manual, and procedures on the Jumper cables and the Jump & Carry.
I just needed the assurance from someone that has a ZR-1.
Thanks again.
