Old 01-01-2010   #11
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Looking for advice on these differential bearing caps
Craig,
Before going to the trouble of crack testing see if the lines will clean up with a little sanding and buffiing. If they do then you are good to go.
Here is a source for a dye penetrant inspection kit.
http://www.cylinderheadsupply.com/spbyma.html
Old 01-01-2010   #12
Jagdpanzer
Jagdpanzer's Avatar
So the caps looked like this on all the ones that you worked on? These really look like cracks and I'll go in the garage now to check it and hit it with some 400 grit as suggested.
Yes
Old 01-01-2010   #13
Polo-1
look the same as the 3 I've done.
Old 01-01-2010   #14
flyin ryan
flyin ryan's Avatar
Question Re: Looking for advice on these differential bearing caps
Craig...if you do buy those billet caps, don't think they are 100% for sure just going to bolt on without at least checking to make sure the housing bore is 'Round' with the caps in place & TQ'ed up. It's like our cam cover's, don't want to mix them up. Little more leway with a rearend bearing because of it's race, but I'd still check...
All you really need is one cap anyways, if you were trying to save a buck. All the rearends I've done, 85% of the time I put a good cap on the one side that takes the major load, Billet caps on both sides is a little extreme unless you've got 16x32's out back .
Old 01-01-2010   #15
Thanks Phil, Kevin and Ryan,
I did a little sanding with 400 grit and I think these are not cracks but will check them again on another day. I sanded a few of the light ones and it appears to get smooth, but the big ones are not really going away and will try to take a better look with light and magnifying glass to see it better. I have a feeling it is as stated and if folks have see it before then probably so and I should not worry about it. I have enough problems and cost already.............
Happy New Year!!!
Old 01-01-2010   #16
4DSZR1
4DSZR1's Avatar
if you compare the lines we're talking about on each cap with the other cap you can see that they both have the same lines in the same relative spot, indicating casting marks.... looks like casting lines to me.
4DSZR1 is offline   Reply With Quote
Old 01-01-2010   #17
1991ZR1
I have similar lines on bearing caps on a spare Dana 44.
When I asked about these lines, I got similar responses. Some people were concerned and others said that it was normal. I notice that the lines do not continue past the mold lines. I would guess that a crack would not stop at the mold lines.
1991ZR1 is offline   Reply With Quote
Old 01-02-2010   #18
Thanks to all that replied, especially 1991ZR1; I am convinced they are castings as they look indentical to the photo posted and in the same exact areas. I guess it is time for some glasses so I can see better. Only the fine lines can be sanded off and I decided to stop on the larger ones as it was just removing material and I am already convinced. Thanks again!!!!
