View Poll Results: Which antifreeze/coolant do you use? | |||
Autozone | 5 | 10.00% | |
Castrol | 0 | 0% | |
Champion | 0 | 0% | |
Durex | 1 | 2.00% | |
Fleetguard | 0 | 0% | |
GM Dexcool | 2 | 4.00% | |
GM Ethylene Glycol | 6 | 12.00% | |
Havoline | 0 | 0% | |
Mobil | 0 | 0% | |
Napa | 13 | 26.00% | |
OES | 0 | 0% | |
O'Reilly | 3 | 6.00% | |
Peak | 0 | 0% | |
Polar | 0 | 0% | |
Prestone | 9 | 18.00% | |
Prime | 0 | 0% | |
Proline | 0 | 0% | |
Shell Rotella | 0 | 0% | |
Sierra | 1 | 2.00% | |
Texaco | 0 | 0% | |
Water Wetter & Distilled water only | 3 | 6.00% | |
Zerex | 6 | 12.00% | |
No additives just plain water | 1 | 2.00% | |
Turbo Power | 0 | 0% | |
Voters: 50. You may not vote on this poll |
01-13-2010 | #11 | |
Re: Which antifreeze/coolant do you use?
01-13-2010 | #12 |
The posts I read, everyone agreed that the Prestone is essentially Dex Cool.
Later-Bob :D [IMG]http://www.axoplasmic.com/800x600/toponzr1.jpg[/IMG][IMG]http://www.axoplasmic.com/800x600/topoffzr1.jpg[/IMG][URL="http://axoplasmic.com/AXOPLASMIC/ZR1.html"]My '95 ZR-1 Home Page[/URL] |
08-23-2012 | #13 |
Straight water + 1.5 bottles of Red Line Water Wetter changed every two-three years.
170° thermostat Stock hoses Fluidyne radiator Lower fan on temps
11-09-2012 | #14 |
I used Turbo Power. Was at Pepboys and meets GM 1825M specs.
Joe 1990 Bright Red ZR-1 #2599 |
07-03-2020 | #15 |
From an old post from Marc
Join Date: May 2007 Location: Addison IL Posts: 195 Default Coolant Recommedation The question often comes up about what is the best coolant for the LT5 engine. I recommend the OE style conventional green coolant. I have found that Dex-Cool causes swelling of the OE LT5 head gasket. Since it is possible that organic corrosion inhibiter softens the head gasket material, coolant containing organic corrosion protection should not be used in the LT5 engine. The possible values of using organic corrosion protection are small. Dex-Cool claims extended service interval and possible longer water pump seal life. It is not worth taking even a small risk for those benefits since the consequences of head gasket damage are huge. Use coolant that has the following characteristics: - Labeled, “For older vehicles.” - Coolant that is colored green - Texaco UPC number 76568 12016 - Chevron UPC number 23968 10000 - GM specification 1825M coolant. The current pn is 12378560. - AutoZone part number 540722. The UPC number is 52948 59081. - Blue Mountain UPC number 74804 01858 The green coolant might not be available in a brand that you like. However the correct formulation is more important than the brand. Avoid “Universal” coolant. There is no need to compromise when the green coolant is available. Retailers like universal products because they reduce inventory costs, universal coolant is not the best for your LT5, the conventional green coolant is. For detailed information about my observations of LT5 head gasket swelling see: http://www.zr1specialist.com/HAT%20W...d%20gasket.htm Sent from my iPhone using ZR-1 Net Registry Some of the p/n have changed since 2007, since I went with the GM BrandImage1593791406.745911.jpg
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR] Last edited by lfalzarano; 07-03-2020 at 12:50 PM. |
03-25-2021 | #16 |
I used the long life orange A/F for a few years then I read on ZR1 Forum that was a no-no
as it caused corrosion & was hard on heater cores. So I switched back to the approved green blend that GM recommended.
lorne # 1748 Stock except for a modified Corsa exhaust. When the flag drops the bull sh1t stops! |
03-26-2021 | #17 | |
"My Recommendation Since it is possible that the head gasket material is softened by organic corrosion inhibiter, coolant containing organic corrosion protection should not be used in the LT5 engine. The possible values of using organic corrosion protection are small. Dex-Cool claims extended service interval and possible longer water pump seal life. It is not worth taking even a small risk since the consequences of head gasket damage are huge."
[I][COLOR="Blue"]Good carz, good food, good friendz = the best of timez![/COLOR][/I] 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry |
