Old 12-13-2009   #11
Default Re: What ZR-1 Item is on you Christmas list.
The rear coilover pieces to finish my conversion
a set of tires for my Shelby Wheels.
Old 12-13-2009   #12
Originally Posted by Ccmano View Post
How do you plan to change out the studs? Seems to me you have to remove the hub, press out the old ones, press in the new ones, and reinstall. Kind of a pain...?
H
There are tools at autozone you can buy.....no biggie.
Old 12-13-2009   #13
Ccmano
Ccmano's Avatar
Without removing the hub assembly?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 12-13-2009   #14
Kb7tif
http://www.lingenfelter.com/engine-packages/corvette/c4-zr1-1990-1995/610-hp-415-cid-lt5\
Just this
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 12-13-2009   #15
Jeffvette
New Z06 calipers available on eBay for $500.
The ZR1 calipers are better than the Z06.
But the ones in the auction at 1,500 USD are not bad considering you are getting the pads. But the cost of the rotors is going to put your nuts in a vice.
Old 12-13-2009   #16
I agree... Unsure if this is true, but they were saying it would cost $5k plus for a "brake" job on a new ZR1. (many said it would be well OVER 5k)
Old 12-13-2009   #17
I figured they were Jeff and also figured the carbon fiber rotors are killer $. Besides does a 15" rotor with calipers fit under an 18" wheel? I imagine the adapter would need to be different also.
Am I correct in assuming the Z06 calipers would use your C5 adapters?
Old 12-13-2009   #18
Jeffvette
You could use my adapter, but it creates such a f'd up offset when going to the larger 4-6 piston calipers you need a new bracket.
To give you an idea, ZR-1 pads are around 100 bucks per axle, the Carbon pads on the new ZR1 are 600 per caliper. That is dealer cost. I priced the rotors out and can't remember what they were, but 1,500 sticks out in my mind. The calipers from GM are cheap. Maybe 250-300 each for Brembo 6 piston with Corvette script on them.
Old 12-14-2009   #19
I already spent on mine and it was the liners/pistons/rods/rings from a new 95 crate motor that I bought from a fellow member; I can't afford anything else.
I still plan on having a Hawaii ZR-1 Christmas though:
Old 12-14-2009   #20
Id settle for a nice Corsa cat back setup.
