Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 12-11-2009   #11
Default Re: Maintenance day in MD - 12 December 2009
I'll be there Capt!
Old 12-12-2009   #12
Aurora40
Aurora40's Avatar
Originally Posted by ZR-1nce removed View Post
BTW Jim, I know the secret for the INFL REST light!!!!
Was this on the '90? If so, it's fairly easy to determine which sensor with a paper clip, then clean the sensor up.
How'd the maint. day go? Also, I don't know what you guys consider nice weather! If the temp starts with a 4 or less, that's not a nice day!
Old 12-12-2009   #13
QB93Z
QB93Z's Avatar
Thanks for the tip.
We didn't get to the INFL REST job. We got side tracked trying to figure why the Theft Deterrent alarm goes off on my 1994 ZR-1 when I open the door with the key from the driver's side.
It was a beautiful day. With the propane heater running, I got the garage up to a balmy 58.
Old 12-12-2009   #14
Originally Posted by QB93Z View Post
Thanks for the tip.
Great day Jim!!!!
Thanks for hosting and thanks for your help with my "alarm" issues.
Old 12-13-2009   #15
that green smiley face is "green with envy" of a work area that is 58* during the late fall/winter!
That's t-shirt & shorts temps! I'll bet that your kidneys don't even get cold if you have to lay on the floor under the car.
You guys are "hooked up & cookin' with gas!"
Old 12-13-2009   #16
QB93Z
QB93Z's Avatar
Originally Posted by tomtom72 View Post
... I'll bet that your kidneys don't even get cold if you have to lay on the floor under the car. ...
Lay on the floor??? That's what lifts are for. The only reason I will be lying on the floor is to look under the tool box when I drop the beer bottle opener.
Old 12-13-2009   #17
Scrrem
Scrrem's Avatar
Great Maintenance day Jim, it was great hanging out with you and David. Yun, you missed a good day. That's the way to do an oil change, on a lift. My next one will be on my lift Here's the photos from our lunch run Enjoy!
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 12-13-2009   #18
Rich
Rich,
Let me know when you are fixing the water pump and I'll try to come out!
Great seeing you again
cheers
Old 12-14-2009   #19
flyin ryan
flyin ryan's Avatar
Great looking pics to see, especially for us stuck in -32ºC/-26ºF today....
Old 12-14-2009   #20
That's what jack stands do for you, your water bottle and your kidneys get nicely chilled on the concrete. Although, the moving blanket does do a fair job at insulating...as long as you stay on it!
