#11 |
i think its a cool gm motor ! who knows we could learn something from it
#12 | |
They aren't anecdotal engines, they are two top-end engines from the same company. No other companies bother with both premium DOHC motors and premium pushrod motors to compare. Some of the stuff you say is equally applicable to both design approaches. As soon as a 4-valve engine has been optimized, all that's left for the daily-driver cammer for more power is more displacement. As far as compression ratios, the LSx motors have similar compression ratios for engines with similar technology. The only 12+:1 engines GM makes are ones with direct injection, a technology that can certainly be applied to a pushrod motor as well. It seems GM hasn't needed to go to that well, probably because displacement is free. |
#13 | ||||
![]() Join Date: Nov 2007
But, to your point, eventually as output demand grows, even a 4-valve configuration eventually has to go to volume increase to get the power. However, I'd love to see the dyno output comparision of Bob G's 427 LT5 vs. an LS7 and see which design makes the better use of the cubic inches...just for grins! ![]() Quote:
I think I understand the bigger pieces of why GM stopped development on the LT5 in favor of the LS motors. But, in view of the changing requirements and technology, it (to me) was a reversion rather than an advance to take the direction for the Corvette that GM did...Just IMO. Time will tell, but my crystal ball says we are seeing the "last hoorah" for that old approach (in the Corvette, at least), unless there is a change in future requirements. It kinda reminds me of epitome of piston engine design for aircraft: The fuel injected, 4-row, 28 cylinder radial, air cooled engine, replete with multi-stage supercharger and intercooler just couldn't compare to the performance of the turbo prop technology. And so it is with the 2-valve, single cam, push-rod design too, methinks. Competition for maybe even more than 505 hp from engines that get over 36 mpg will drive the last nail in our beloved big cid 2-valve push-rod thumpers. They'll live on in trucks and heavy equipment, I recon, but I will not be surprised to see them gone from the next generation of the Corvette...assuming there will be one?? ![]() P. Last edited by Paul Workman; 12-10-2009 at 09:01 PM. |
#14 |
![]() Join Date: Aug 2005
[quote=tomtom72;76365]I was watching one of the episodes of that Ultimate Factory series over the weekend and almost fell over when they showed the new base V6 for the camaro.
![]() *Just got my '10 "LLT-V6" Camaro, absolute screamer! Not as quick as my '91 Z but that is just a few mods away. This motor seems to respond well to basics exhaust iat relocation etc. But the best will come after the ECM software access gets solved. Just a few basics on this V6: Forged crankshaft, 6 bolt mains, Direct injection, polymer coated pistons, etc.* Watching them build the motor; I thought I saw some genetic connections to our LT5's. *No real LT5 heritage that I am aware of. Actually, this engine was developed by Holden and produces in the 380+ hp range with a tweaked "open" engine management computer. Check out the CAMARO5 forum you would be amazed.** Made me think what would direct injection do for an LT5? Good Question. |
#15 |
![]() Join Date: Oct 2008
Paul,
I think you are overlooking a key set of variables in why the LS series of OHV engines were selected and have been countinues over the past two Corvette generations. 1. Vehicle aerodynamics - a lower profile engine (i.e. LS versus LT5) were a lower profile allowing for significantly better aero characteristics. This in turn leads to better fuel economy. 2. Manufacturing - far easier decking in the vehicle assembly process. 3. Power density - HP per weight of the engine and HP per package size of the engine. The weight savings also affected overall vehicle weight the potential effect on acceleration. 4. Cost - self explanatory in the case of the LT5. But Chevrolet did put a lot of cost into the LS (from a design standpoint). But with the ability to amortize the cost over many more units (trucks included) the variable costs could be contained fairly well. |
#16 | |
I don't believe Holden has ever made any noteworthy engines. The GM corporate (Buick) V6 and (Chevy) V8 have been godsends to their product lineups. I guess one thing that relates somewhat to the LT5 is the way the V6 has grown product-wise. Initially it was a fairly expensive engine, and an extra cost option on the CTS. Somewhat like the LT5 it was costly and not widely available. But as time went on, the engine has grown, presumably the cost has come down, and now the V6 is available in all sorts of cars, from the Camaro and STS down to Saturns and G6's. Maybe if they'd stuck with the LT5, the price would have started to come down, and it would have been used more widespread. Though I suppose the Northstar paints an opposite possible fate, where the engine may have been so cutting edge that the company would just sit on their laurels and not update it, until it was obsolete and faded away... |
#17 | |
![]() Who knows what the sports car will evolve to, including future Corvettes. But, if there is to be a future for the Corvette, I am willing to move a big portion of my chips from the pushrod square onto the DOHC square. ![]() FWIW, P. |
#18 | |
The only problem preventing the scenario you mentioned above is the investment required to re-engineer and retool their existing lines. The Corvette shares much of the tooling with their truck brethren and the investment would not likely be there without some ability to amortize it over a broad spectrum of vehicles. The Corvette would not likely drive a new architecture again. The LT5 is precisely the experience that would tell them a Corvette only architecture is not the way to go - at least in the near term future. |
