11-17-2009 | #11 |
Re: Diff Question
Here are the rest of the pics of the "Hetrick Method".
11-17-2009 | #12 | |
Re: Diff Question
I got mine from flea bay: http://cgi.ebay.com/ebaymotors/DANA-...Q5fAccessories Interesting approach to the drain plug, never seen that. Rich
1990 Bright Red Coupe #608 380 Stroker, Ported Heads/Intake/Housings/TB Haibeck Secondary Delete Chip / Pete's Cams George Braml Intake / FIC Injectors Coated SW Headers / Corsa Bill Boudreau B/B ZF6 / Viper 4.10 gears Ron Davis Radiator Pioneer AVIC-Z140BH NAV Fikse FM5's 285 / 335 / C6 Brakes WAZOO Member Last edited by Scrrem; 11-17-2009 at 02:18 PM. |
11-17-2009 | #13 |
Re: Diff Question
11-17-2009 | #14 | |
Re: Diff Question
Thank you Sir I just ordered my set Dave |
11-18-2009 | #15 |
Re: Diff Question
Pretty slick idea you have there; I think you are right and less likely to affect strenth of the case. I guess I might want do the clutch pack too while I'm at it. Thanks for the idea.
11-18-2009 | #16 |
Re: Diff Question
Wow, this is three rear axle's getting upgrades at the same time. I guess the next post will see is a search for new rear tires
Rich
11-18-2009 | #17 |
Re: Diff Question
Is the GM service manual for a zr1 different than a regular 91 vette?? I see the Lt5 supplement all over ebay and no ZR1 manuals.
Dave |
11-18-2009 | #18 | |
Re: Diff Question
Rich
11-19-2009 | #19 |
Re: Diff Question
I have been looking for or equivilant GM sealent for the rear end #9636067 and none of the parts stores can cross refernce it and the dealer dosent show it. Is it a silicone or ureathene? Any imput or experiance on this would be appriciated?
Dave |
11-19-2009 | #20 |
Re: Diff Question
Dave, I use a sealant called "The Right Stuff". Use it on LT1 intakes and LS1 stuff and have never had an issue with it.
