Old 08-03-2009   #11
Default Re: 90-92 Mod test
Rough start, I went and put it on the dyno....something is not right....first 2 runs were 276 and then 303hp. I need to figure out whats going on....
Well, I switched to a chip that opens 2ndry TBs immediately, I then peeked under the plenum as I opened the TBs. They opened up and held vac, so that is not the issue. The chip also also turns on full power all the time.
I think my power issue was power key, also feel a periodic miss under full power.....probably a coil as I put the old ones back in after I had an issue that turned out to be the TPS.
Once the 92 is done, I will put the new coils back in....
Old 08-04-2009   #12
flyin ryan
flyin ryan's Avatar
Originally Posted by Ccmano View Post
If you look down the back of the plenum under the MAP sensor you can see it in the group of exposed wires there.
H
Six (6) wires total, it can be a pig to get on one, but they are there. I used the green wire. Worked fine.
