06-17-2015 | #11 |
Re: LT5 miss at all speeds
I like the MSD 8224 DIS coils.
Not that I notice any improved performance, I just like their red color http://www.msdignition.com/Products/...wer_Style.aspx
06-17-2015 | #12 |
I bought mine from Advance Auto Parts. You can get MSD brand from them and usually have coupon deals to bring the cost down.
06-17-2015 | #13 |
Jerry supports the group. Buy them from Jerry.
06-17-2015 | #14 |
A couple months ago, I got 4 new AC/Delco coils from Amazon $100 and a few cents delivered.
06-17-2015 | #15 |
DANG. That is a good deal. I paid a little more for the BWD brand.
06-22-2015 | #16 |
Ok everyone, Got the plenum off with no problem. Way easier then what I had imagined with all the good info on the Registry. Took about 40 minutes and broke nothing. However, I tried a suggested method for anti-freeze removal, just drain the plenum, and I would not advise that method. After releasing the plenum, antifreeze began bubbling up from the two holes in the injector housing. Plugged the holes quickly and then drained the radiator. Saving ten minutes at first cost me hours in cleanup. Dang, I hate antifreeze. The valley was extremely clean, prior to the antifreeze dump and all connectors and hoses are in very good shape. Well, at least I know the valley drain works just fine.Tested the wires and they come in at 7.5-9 K ohms for all, well within spec. Also checked the coils, all 4 coil resistance within spec. Also did a visual of the coils and they all look good, no signs of heat deterioration or cracking so I am going to let them go and just change out the injectors. I may end up regretting this decision but I was going to go with stock coils anyway so I don't see the advantage at this point. This is a very low mileage car. Looking forward to installing the new FIC injectors and getting her back on the road.
Big D 69 L46, M21 90 ZR1 95 Suzuki 1200 Bandit 2014 Triumph Thruxton |
06-22-2015 | #17 |
Never heard of draining the coolant from the plenum
I would suggest blocking those two coolant passages in injector housings. That would then be an end to any messing with coolant when removing Plenum. Oh. Just make sure when you get Plenum back on and coolant refilled that the two Injector Housing Coolant Manifolds are getting warm within a minute of firing up the engine
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-22-2015 at 09:21 PM. |
06-27-2015 | #18 |
I'll be doing the same thing this week. Let us know how everything turns out. Let me know what you think of the FIC injectors.
Ken "IMZZ" 1991 ZR-1 Corvette 1990 MX-5 Miata |
06-29-2015 | #19 |
got the new FIC injectors in. So far so good. They look high quality and I think they will do the trick. Ordered them on Tues, got them Weds. Easy install. I released the old injectors from the fuel rails first and then removed them from the injector housings. Watch for fuel leaks. Have rags available. Seemed to be the easier way. Then installed the new injectors to the fuel rails and then installed them into the injector housings. All went together real easy. Taking your time is the best advice and follow all of the good info on this site. Helped tons. Took it out for a test beat and it screamed to 6500. Like a whole different car. I do have one problem, I have a slight miss when at idle or just idling down the road. Anything off idle up to floored and it doesn't miss at all. Wasn't able to get new plugs for it on Sunday so I had to re-install the old ones. Hoping maybe it is a bad plug. Didn't have time to troubleshoot any further either. All coils and wires checked out within specs. Won't be able to get back to it until next weekend.
07-17-2015 | #20 |
hi everyone, couldn't figure out the miss so i put in new coil packs, wires and plugs. Still missing at low idle and while idling down the road. Also, get a bad hesitation off idle. Still screams to 7 grand though. So tonight, after putting the new plugs in, i have isolated the miss to number 6. Pulled the wires on all other plugs and the idle changes noticeably except for number 6. Pulled the #6 plug and it is bone dry, never saw any fuel in the short time it was running. The injector ohms out correct. Fuel pressure is good also, holds after shutdown. Could the new primary injector at # 6 be questionable?
