Old 11-07-2020   #11
KJL
Default Re: cam position sensor
Phil-
I found a thread back in 2017 where you found a sensor that would work for 1990 ZR1s and modified it to fit. Are still making these for people willing to pay? I don't need one at the moment but willing to pay to have one on hand. Currently my 92 is leaking oil and likely needs at least a new seal. I am going to start a new thread for that to see if anyone knows of the correct seal size. But I am afraid of messing with it. Looks a beast to get out even though it is about 12 inches from my hands.
1995 ZR1 #159
1992 ZR1 #280
1996 Collectors LT4 (Stock)
572 rwhp
Old 11-07-2020   #12
Jagdpanzer
Jagdpanzer's Avatar
I can make one if you need one.
Stock sensor uses a 21mm OD 17mm ID 2mm width Buna-N O ring seal. Jerry has them:
https://www.jerrysgaskets.com/seal-c...r-90-95-7-5c5/
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 11-07-2020   #13
KJL
Talking Re: cam position sensor
Thanks for the info, Jerry does indeed have them. I don't know why I don't just check there first.
Now all I need to do is figure out how to get to the darn thing.
I think all I need to do is remove the ASR bracket.
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 11-11-2020   #14
Poussin
Originally Posted by ZR1CK View Post
Hey guys.
I've also been having an issue with my '91 Z in getting a fault code 31 and I have the same or similar "Service Manual" but for the 1991. My engine does not run okay, it stumbles, bucks and sometimes stalls. The two pages you show here are the same as I have in my manual. I've gone through that diagnostic tree, cleared the code, checked the wiring & connections, measured the voltage, measured the grounds and keep getting a code 31, leading me to believe it must be the cam sensor. According to the info on the first page (6E3-A-50), last paragraph under Diagnostic Aids, "When probing CKT 633 at the ECM, DVM should read ignition voltage with the ignition "ON"...", (that is ignition ON, engine OFF) which makes sense according to the diagram at the top of that page. BUT, in the last paragraph under Test Description, it states "Normal voltage produced by the camshaft sensor is 0 to 5 volts", which does not make sense. The MAP sensor, Throttle Position sensor, IAT sensor and others have a 0 to 5 volts referencing. I believe that the "0 to 5 volts" for the cam sensor is stated in error as I have found several other errors throughout the manual. I purchased a NOS (I hope) cam sensor through e-bay and did a bench test. I applied 12 volts across terminals "A" and "C" and a DVM across terminals "B" and "C". The DVM read 12 volts until I placed a wrench near the face of the sensor, mimicking the movement of the reluctor wheel on the camshaft, at which time the voltage dropped out. Moving the wrench back and forth altered the output voltage up and down as in a square wave signal. According to the testing procedure in the manual, this sensor is working backwards, whereas I should be reading a high voltage when the wrench is near the face of the sensor and low when taken away. I'll be installing the sensor today and see what readings I get then. As far as the gap goes, I believe it needs to be between 1 and 5 mm, according to other references I've come across. I also butted the old sensor against the new one and they are exactly the same length, which tells me the gap will be exactly the same as the old one.
The reason I bought the sensor on e-bay instead of a Chevy dealership or any of the auto parts stores is...nobody, and I mean NOBODY, has one. And if you do find one for sale, you will pay dearly. Nothing against e-bay, I've purchased many items through them and have been completely satisfied. It just so happens I stumbled across it while searching just for the heck of it. And I did pay, I had to, the motor can't run right without it. Which leads me to my next issue.
The "General", back in the day, decided to build this "elite" engine to compete in the high performance world. And the results were awesome. BUT, how can you design and engineer such an "icon" and not factor in such a trivial replacement part that disables this icon useless without it? It is baffling to me to say the least. I have been able to find replacement sensors for the MAP, IAT, TPS, crank and pretty much every other sensor fairly easily and at a fair price for the engine except the cam sensor. From what I gather, the C4 LT5 cam sensor is only applicable to the C4 LT5, whereas the other sensors on that motor are compatible with other engines. Therefore, manufacturing aftermarket parts can be worth producing if there is a demand from a large category. BUT, with the C4 LT5 population being a very small one, it's not worth reproducing that cam sensor. Who's the brainiac that thought this up? If you cannot replace a failed part of this "icon", even as small as a simple cam sensor, then this "icon" is no more than a pile of scrap metal, or a boat anchor. Sorry.
If this sensor I just bought works, then I'll most likely be selling the "Z" in the spring. If it doesn't work, then I'll continue to search for one over the winter that does work OR replace the motor with an LS. I've pretty much bought the "Generals" vehicles throughout my life. Currently, along with the "Z", I own a 1992 full size Blazer, a 2009 Impala, a 1972 Corvette and a 1969 Chevelle. I'm not bragging, just giving a representation of the type of vehicles I lean towards. But after this fiasco, the issue that the C7 owners are having with the defective wheels and the issue of the ten year ignition problem in other Chevys in the past, tells me that the hierarchy at General Motors really places quantity well over quality, in my opinion. If it sounds like I'm venting, you'd be right. My next vehicle WILL NOT be a GM, most likely a Ford or Mopar.
I have exactly the same problems, but my cam sensor is brand new... I've place a new principal ground, engine run perfectly during 3 minutes and after sames problems.
i've checked the sensor tension like manual says, look at videos.
If you have any informations more or suggest?
Fist Test D3 - Ground
https://youtu.be/XWhSqp19LXM
Second Test A - Ground (2 parts)
https://youtu.be/YXQpnXggxUs
https://youtu.be/-Uq-8Jdm6GY
Here, electric noise and engine problems..
https://youtu.be/PxFXEeReQZE
Poussin is offline   Reply With Quote
Old 11-12-2020   #15
KJL
Phil-
I sent you a PM regarding the sensor but I am not sure it went out. I am interested. Will it be compatible with a 92 and 95?
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 11-12-2020   #16
CamP
Anyone have a spare camshaft sensor they are willing to part with? I'd like to add one to my spares jic I need one in the future.
PM me if you have one, Thanks
CamP is offline   Reply With Quote
Old 01-03-2021   #17
Poussin
Problem solve with new ECM
Old 01-04-2021   #18
ZR1CK
Great...just a matter of "process of elimination" huh? With all the new and advanced technology, sensors, relays, and whatever else they can cram into the "works" now, it just takes longer to find that "needle in the haystack". I have a strong hunch my problem lies in the ECM also. Need to do one more test before I make a decision to get the ECM into the ICU!
ZR1CK is offline   Reply With Quote
