08-15-2016 | #11 |
Re: Stuck!! No crank ! LF some input and help !
That switch is such a pain in the @$$ to get to. If mine ever goes I'll bypass it. I've done the relay mod and so far no issues.
08-15-2016 | #12 |
I did the relay mod as well and no issues since. Also make sure you have a good battery. I figure with the relay mod I took a lot of other things out of the equation so if it fails to start again I know to go digging for the starter...
08-15-2016 | #13 |
I swapped clutch neutral safety switch on my 84. It is an absolute BEAR to replace. The seat MUST come out. The one on my ZR is bypassed which is relatively easy to do.
08-15-2016 | #14 | |
Starter Relay, Wiring Harness, and Plugs Tricks |
08-15-2016 | #15 | |
In other words, if you have a (serious) VATS/clutch/ignition issue, you might still have a problem even with the relay mod. |
08-15-2016 | #16 |
Got the clutch switch and connected the wires together. Still no start. No noise at all no clicking etc. I'll make a short video. I don't see any gauges dimming when turning to start. Thinking to check the ohmage on the key and just do the vats bypass for that while the kick panel is out.
08-15-2016 | #17 |
I'll add this to the main page too. Here's what I see.. This was after I tied the clutch switch wires together just now.
https://youtu.be/d_rI6IdEKsg |
08-15-2016 | #18 | |
Another benefit to this quick, temporary fix is, if the car starts with this method you confirm your starter motor isn't the problem. |
08-15-2016 | #19 | |
Next on the list and will try it shortly. I will need to have someone in the car turning the key I assume to get it to fire? Regardless like you said if the starter turns then I know it's not the issue ! Will report back shortly thanks ! |
08-15-2016 | #20 | |
