#11 | |
![]() Join Date: Apr 2007
#12 |
Just received 8 (only) of the sealed power HT 2236 lifters in the mail. I emailed the seller that I was short 8 and he refunded half my $102. Oh well.
I thought I read somewhere that these lifters would suffice for the stock cams so being cheap ie 102 for 16 lifters, I jumped on them. Are the mellings that much better?
Sam 1991 ZR-1 :salute: |
#13 | |
![]() Join Date: Jul 2010
So long as there isnt any excessive wear and you are using teh appropriate oil, you should be fine. Anyone have the p/n for NOS GM lifters? peace Hog |
#14 |
![]() Join Date: Dec 2003
The Scotchbrite i'm talking about is the green scrub pads you buy in the sponge section at your local grocery store made to wash dishes and used by hand,some sponges have this stuff on one side.
I use this stuff to clean head & cam cover surfaces from old aneroabic sealent w/parts cleaner it does not take off any aluminum to do so you'll work your fingers down to the bone. Of course anytime you take things apart you wanna clean eveything thoroughly before putting it back togather,i thought this was common practice when assembling a motor,i didn't think i needed to explain this. Sorry for the confusion. Pete
#15 |
Just so you have something to compare, here's a pic of my cam bearing surface when I removed covers earlier this year. Took off cam cover to replace breather vent material to relieve crankcase pressure.
![]() ![]() ![]() As Pete said I used the Scotchbrite to clean surfaces before reassembly. BTW, cams had already been run several thousand miles at this point.
#16 | |
![]() ![]() Join Date: Nov 2007
P.
#17 |
![]() Join Date: Sep 2012
Is that normal wear for 10k miles? What's it going to look like at 40k miles?
#18 |
I can't honestly tell you that what you see in the pic is wear from having run cams. For all I know this is what it looked liked originally. The motor these covers are from has about 30k miles on it. As you can see from the corresponding cam journal, there does not appear to be any damaging effect.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 12-01-2012 at 12:14 PM. Reason: spelling |
#19 |
True, true...
#20 |
Here's a couple pics after the scotch brite. The only stuff I had on hand was green. Also used wd40 which seemed to help a little. I don't think I want to go any further. You can't feel the scratches that are left. Thanks for the pics of the cam cover journals. Mine are similar.
Sam 1991 ZR-1 :salute: Last edited by Torchred96; 12-01-2012 at 09:01 PM. |
