04-18-2011 | #11 |
Re: Water pump replacement.
Rick and Jerry,
You both cleared up the bolt mystery. Thanks
04-18-2011 | #12 |
04-18-2011 | #13 |
Whooo Hoooo!!
04-20-2011 | #14 | |
Rich
REBelZ '92 ZR-1 Yellow/Black #031 |
04-20-2011 | #15 |
Wow, thanks Jerry, you're awesome!
Never seen that chart before. That is the kind of chart that should have been included in the service manual. Or is it in there an I just didn't see it? Should be no problem getting those bolts sorted now!
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B] 1990 Corvette ZR-1 [/B][I] White/Flame Red, #2299, mostly stock, 144K miles.[/I] -Cams timed to the '93-'95 405HP LT5 stock timing. -IAT sensor relocated to below front bumper. -Haibeck hoops installed in airduct. -OBX cat-back exhaust. [COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR] 1993 Corvette Coupe Black/Black, 6-speed (SOLD - October 2009 :hello:) |
04-20-2011 | #16 | |
I'll Photoshop the drawing to switch the C&D bolt around like they should be.
03-15-2020 | #17 |
Is this picture hosted anywhere else or can you repost bolt diagram please? Thanks!
03-15-2020 | #18 | |
https://www.jerrysgaskets.com/water-...ew-90-95-20a1/ or this image
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 03-15-2020 at 10:50 AM. |
03-15-2020 | #19 |
That's what I needed...THANKS!
06-19-2021 | #20 |
Hello!
Could someone tell me which water pump bolts need loctite 565? Regards Chris Sent from my EVR-L29 using ZR-1 Net Registry mobile app |
