11-15-2020 | #11 |
Re: SuperPro Bushings back in stock at C&S!!!
Ok. I stand corrected on SuperPro bushings. When they're used in the rear arms, they must be soft enough to allow the arms to rotate as they move up and down.
04-26-2021 | #12 | |
if I understand you right this kit is not recommended to use? http://www.bde-systems.com/1984-1996...-complete-kit/ Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin 1994 ZR-1 #112 Admiral Blue/Black Dana 4:10 Aluminum flywheel Corsa exhaust Watson headers Haibeck chip 470 HP/399 RWHP 1991 ZR-1 #400 White/Red (SOLD) Dana 4:10 Powder coated engine Haibeck performance chip Borla exhaust |
04-26-2021 | #13 |
Here is a good video where the quality is explained.
https://youtu.be/4e4CtEwjOnk Sent from my SM-G955F using ZR-1 Net Registry mobile app
04-26-2021 | #14 | |
That being said, the silicon lube provided with almost all polyurethane bushings doesn't wash out, dry up, or need replaced. By the time you would have to re-lube, the bushings would be shot anyway. |
06-06-2021 | #15 |
And they are sold out again. Crap timing, as I'm just about to swap my springs.
1990 ZR-1 # 996 "All Corvettes are red. The rest are mistakes." - John Heinricy |
06-06-2021 | #16 |
Check Eckler?s, Eric. I was able to find them there the last time C&S was sold out.
06-06-2021 | #17 | |
I'll have a look.
06-07-2021 | #18 |
My bushings from them have been backordered since March 15th....
07-05-2021 | #19 |
And they actually have them in stock. My set just arrived. Hope to have them installed ASAP.
11-15-2021 | #20 |
I just bought a set from Ecklers in case anyone is looking.
