#11 |
God Lee! Lean misfire!!! You're maxed out on the BLMs.
Need to re-tune that. Call me.
#12 |
![]() Join Date: Mar 2007
Changed the fuel filter, no change....but then I noticed that my Tech 1 has a BLM reset button, that sets BLM counts back to 128 and removes the "learned" counts....
Will see what happens, still show knock Put some Fuel Inj cleaner in also...I did notive that timing is at 1-2 degrees vs the -4 to 8 it was at... I also noted that on decel timing drops to -10 Tech 1 should have a label: This is not a toy..... ![]()
#13 | |
Decel does pull timing. If you noticed a diff after fuel filter, how about the quality of the fuel in the tank? Has it been sitting around for a while? Do you notice WHEN the knock occurs? The scan tool will detect knock at start up and shut down but those should be of no concern. I would reset BLMs and Spark Counts w Tech 1 then drive around a bit. See what happens. You should datalog with a scantool so we could see what is happening when.
#14 |
beginning to think its the knock sensor filter/elec spark control....unplugged the knock sensor and still getting 10 degrees of timing retard at idle, and when I floor the car the timing drops to 6-8 degrees......surprised the car is this fast
#15 |
FSM says that if the knock is present without a code 43 ESC is bad, I have an internal engine problem or the wire is picking up a false knock.
Anyone know who sells the ESC module?
#16 |
![]() Join Date: Dec 2003
Get new knock sensor,done.
Pete
#17 |
I unplugged the sensor and the knock was still there..per FSM I believe that points to the ESC...
#18 |
If you don't have a short.
Change knock sensor,it's cheap and will save you time and headache. Just trust me on this. Pete By the way the 1990 knock sensor is different.
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 04-22-2012 at 11:18 PM. |
