04-25-2016 | #11 |
Re: vacuum issues,....
Sorry to throw this off topic, but as I was looking at vacuum pump, I saw this.....I didn't have my manuals and it was getting dark at storage unit. What is it and shouldnt it be plugged in??
04-25-2016 | #12 | |
Did the Vacuum Pump run for a few seconds and then shut off for how many seconds? If it ran and then shut off and ran again you are good to go and any vacuum leaks (depending on how long the vacuum pump rests) can be fixed at a later date with no loss in secondary function.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-25-2016 at 07:47 PM. |
04-25-2016 | #13 | |
Well got WAY ahead of myself.......I let the car sit and idle, after about 10/minutes backed her back into storage unit. Went to restart and turned ignition and no vacuum pump. It buzzed for about 1 second and that's all. The 09 code reset, and remains so. |
04-26-2016 | #14 |
i have a vacuum pump I am selling if you are interested. PM if soi
04-26-2016 | #15 | |
04-26-2016 | #16 |
04-26-2016 | #17 | |
I would first check voltage at the pump to make sure you have 12 volts and to make sure that voltage is not varying. The car will run fine without vacuum pump unless you have the power key on and you are in a mode where the secondaries will function. Then you will notice not as much power as you are prolly used to (when Plenum Vacuum is low and Power Key ON). Check voltage at the Vacuum Pump Electrical Connector and if you have 12 volts, plug connector into the Vacuum pump. Now disconnect the Vacuum line from the pump ....which the pump should run continuously with vacuum line disconnected. (Key ON)
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-26-2016 at 04:58 PM. |
04-26-2016 | #18 | |
04-28-2016 | #19 |
Hey guys . Our newly purchased 1995 ZR-1 definitely has a vacuum leak as the pump keeps clicking every 3 to 5 secs . There are no fault codes on the dash and the car runs quite well . Will this leak be an issue for our drive to BG ?
Thanks Mike PS just read through the vacuum leak tech section . Thanks Dynomite . I will do the leak test prior to a removal of the plenum to at least confirm if the leak is not under the LT5's monster intake plenum ,,, Last edited by Tripler; 04-28-2016 at 07:13 AM. |
04-28-2016 | #20 | |
For my 95' I installed Jerry's Secondary Vacuum System and now have zero vacuum leaks. It is amazing when you inspect original vacuum systems how many of the connectors actually leak. Same goes with Jerry's PVC System new rubber components (one tube with dual PVC inlets, two Injector Housing Ls, and one Dual Connector on top of the Dual PVCs). NO MORE Nylon Ties, and NO MORE Hose clamps. 1995 LT5 SPECIFIC TOP END REBUILD TRICKS A 1995 Top End was rebuilt and best tricks linked here Post 230 - 1995 LT5 SPECIFIC TOP END REBUILD TRICKS
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-28-2016 at 07:51 AM. |
