04-26-2017 | #11 |
Re: 91 ZR1 - Latest Issue
Thanks Dynomite, so it appears from what you are saying, I just need to pull the Plenum and start doing the work you recommend for the repair Possible to partially pull the plenum, prop up from the front without disconnecting all the hoses in the back to get to where I need to go? I did that several months ago to fix the famous vacuum leak in the front. Thanks for your help!
04-26-2017 | #12 | |
Some information for you....... TOP END RESTORATIONS SUMMARY Post 62 - 1990 (#2067) LT5 Top End Rebuild (C5 Z06./Wilwood Brakes, SW Headers, Aluminum Radiator) Post 76 - 1991 (#1427) LT5 Rebuild (C5 Z06/Wilwood Brakes, SW Headers, Ron Davis Radiator) Post 119 - 1990 (#3032) LT5 Top End Rebuild (Fluidyne Radiator) Post 133 - 1990 (#0072) LT5 Top End Rebuild (Ron Davis Radiator) Post 230 - 1995 (#0186) LT5 Specific Top End Rebuild (C5 Z06/Wilwood Brakes, Fluidyne Radiator) Post 261 - 90’ (#8550) Corvette (L98) Modifications (SW Headers, Ron Davis Radiator)
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-26-2017 at 01:00 PM. |
04-26-2017 | #13 |
Latest Latest Issue-
Just got back from the shop where the car is. Now it won't crank over (all lights are on and getting plenty of power) Can this in anyway be related to the plenum oil leak that is supposed to be draining down the Valley Drain. Perhaps some oil contaminating the starter? A coincidence the starter just went bad? When it rains... Thanks |
04-26-2017 | #14 | |
But yes....on the Plenum removal.......always recondition the starter Solenoid points and check starter bearings. Also recondition the Valley Drain and other items mentioned in post above.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-26-2017 at 04:55 PM. |
04-27-2017 | #15 | |
04-27-2017 | #16 |
Keep the faith and smile.. That LT-5 sounds incredible when it's winding up on the road! Small stuff for our '91's. Gotta love working on this piece of art.. I've really enjoyed tuning this engine. Like having two engines under one hood with 16 injectors and a "two stage" intake manifold. Not another one like it on the planet.. Good luck and keep us informed on your progress. Good it's not the oil pressure sending unit.. your repairs are, comparatively easier than that little dude..
05-03-2017 | #17 |
My ZRI is now in the shop. The mechanic says there is a combination of oil and coolant in the valley drain. He will clean out the valley drain but where could the coolant come from? Thanks
