Old 02-14-2017   #11
Default Re: Went to Cory's Today!
Originally Posted by RodB View Post
I do wonder if or how a 25 year old airbag would deploy if everything was working as it should. Thankfully I've never had to find out but I do wonder.
A valid concern. All I know is it "may" not deploy with the Blinking INFL REST light error. 9 times out of 10 its a corrosion issue where the frame mates with the airbag sensors and is a well known MY90 only issue. A little rust removal and cleaning and a little dielectric grease can resolve the issue. Nobody ever wants to find out
Old 02-14-2017   #12
Scrrem
Scrrem's Avatar
Its your call but that wont fix the problem with deploying the airbag when you might need it in an emergency. (This is a safety issue) I remember reading the procedure how to fix this problem correctly in an old registry mag. I could look for it and make you a copy.
Your decision.. LMK GC
Daryl,
Can you shoot me a copy of that article? I may be battling that demon when my car come back from paint I have done all the sensor cleaning and even replaced the sensor, still no joy. Hope it's not the DERM. Is it something you can get into a PDF and email it?
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 02-14-2017   #13
Originally Posted by Scrrem View Post
Daryl,
Rich
Will do! Crap I hope not. The MY90 DERM is a one of!!!!! totally different connector round vs. the square plug in the later years.
Wont be until tomorrow. Vday date night after work lol. It in one of the old registry mags and will take me a while to look for it.
Old 02-14-2017   #14
I have left my battery in the z 24/7/365 for five years because I'm concerned that repowering the electrics will cause something to fault! Someday I will need to replace that battery.
I completely disconnect the battery in all Zs if left for over a day.....have done that for a long time with NO issues. Do have fully charged battery at all times by using the Disconnect. Even an overwinter (as long as 5 months) disconnect fires right up in the spring.
See Item #4 Starter, Starter Relay, Wiring Harness, Battery, and Plugs Tricks
Old 02-14-2017   #15
You must have the clock on the radio reset down pat Cliff !
Old 02-14-2017   #16
Default Went to Cory's Today!
I listen to XM and have cell phone time
Old 02-14-2017   #17
32valvesftw
About the old airbag, I have concerns about that as well, to the point where was thinking about replacing the steering wheel with one of those cool Momos.
Old 02-14-2017   #18
MickeyD
I'll take a copy of that too. I worry more about what happens if air bag deploys after 27 years than not at all. Guess I'll takes my chances.
1990 ZR1 Red/Black #2469
1990 ZR1 Black/Black #843
1993 ZR1 Ruby 40th Anniversary #112
MickeyD is offline   Reply With Quote
Old 02-14-2017   #19
jss06c6
Mike,
You made the right decision if you felt good about it! We did well with seat belts and no air bags for years. Our Z has shoulder belts as well, so I'd feel quite safe with a new steering g wheel without the airbag. Glad your happy with the fix, that's what counts.
Old 02-14-2017   #20
MickeyD
Originally Posted by jss06c6 View Post
Mike,
Thanks Steve!
