Old 09-07-2022   #11
Default Re: Question on Cluster LCD Panel Backlighting
Originally Posted by dredgeguy View Post
92, in the garage, key on not running. Gauges are backlit. No change in brightness if the light dimmer is adjusted.
Thanks. Now to find where the change was made for that (my guess in the CCM)
Watson Headers (2" Primary) - Borla Catback
Old 01-06-2023   #12
Found my Answer.. CCM for 1990 controls the Backlight differently than the 91-95 (96)
I always felt like it was harder to see the LCD on the 1990 vs the 1991 dash setup I had before.
Last week I successfully swapped in a 1991 CCM into my 1990 ZR-1. it has been programmed for the correct mileage as well as set correctly for the ZR-1
Now I will see what I can do to add the DAB (Delayed Accessory Bus).
Old 01-06-2023   #13
Originally Posted by G8nightman View Post
Yes in garage low light it is Dim once its out in day light its fine.
This has been my experience with my 90 as well.
Old 01-06-2023   #14
Muhhhhaaaa hopefully this works
