#11 | |
![]() Join Date: Jun 2005
In fact, now that ole "Dynomite" bought my last Fluidyne, that's a great subject for him to test....right....Cliff? Cliff...are you there? Cliff...
#12 | |
![]() Join Date: Jul 2010
Rather than seeing a straight up power increases from lower ECT's alone, I was thinking more towards the detonation resistance it may provide, but that is a moot point considering the excellent detonation resistance the LT5 head provides. I know this was a trick in some of the aftermarket calibration kits offered for the LT1. Just enjoying the conversation. Nice to know that these parameters are adjustable in the OBD1 calibrations as well. Those extra 1-4 holes in the thermostat would lengthen engine coolant warmup times, I would guess. But if they help overall cooling, that might be a good alternative for some.
peace Paul ZR-1 Net Registry Member #1494 |
#13 | |
So the range of 80C to ~114(check me on that Todd) is the optimum CTS range for the ECM to LEARN and modify the base VE Tables through the process of the INT(STFT) leading to the BLM(LTFT). P.S. 114 is too high. I think it's more like 104C..
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 04-21-2016 at 10:04 PM. |
#14 | |
![]() My BIGGER issue was a Thermostat that was restrictive and started to open at 195 deg. And the Old Radiator it turns out had leaks on the plastic ends. Fluidyne is a very nice radiator and did not require shaving the internal fan shroud baffles. (The existing baffles were about 1/8 from touching the thicker Fluidyne. I installed New Thermostat and also installed Jerry's New Heater Nipple when I had the thermostat housing removed (DO NOT ASK) ![]() Anyway.....I did a run 87 deg ambient and temperature rose to 188 deg on Coolant System.....with a Fluidyne. That AIN'T BAD given before the Fluidyne and Thermostat temps rose to 213 deg on a 80 deg day. |
