Old 11-15-2012   #11
scottfab
scottfab's Avatar
Default Re: LTPWS question. "Scottfab"...where are you?
Originally Posted by SteelBlueZR1 View Post
Timely post, as my Service LPTWS light has come on for a few minutes on two occassions. Both times I had spun the tires on full throttle first / second gear runs, and then came into the same part of my town, where the light came on. Is it possible there is some radio interference causing this, or a different in average wheel rotations from the tire spinning runs?
There are two, count them, two lights for the tire pressure warning system. One indicates a system failure (the one you're seeing) and the other indicates a tire has low pressure (no matter what MY you have)
The only time I've seen interference is with other ZR-1s around. If you're in a crowd of ZR-1s and someone has a low pressure issue it can kick you SERVICE LTPWS light on.
That's not to say that some radio interference could not interfere with one or more tires reporting in a timely manor but I do not have any direct experience with that.
As far as a WOT run causing a problem? I can't see how.
Scott
Old 11-17-2012   #12
SteelBlueZR1
Thanks Scott. Actually, the light came on after the Wazoo Ice Cream Cruise, and has not returned, so it must have been from a fellow ZR-1.
Bert Rankin
1991 ZR1 Steel Blue / Steel Blue
#1029
Haibeck chip, slotted rotors, camber brace, C-beam plates, OBX exhaust, Nitto NT555 tires
[SIGPIC][/SIGPIC]
Old 01-20-2013   #13
Brad Sewell
By any chance is that same part of town approximately 5 miles from your point of origin?
My light comes on after 5 miles which I believe I have read to be the diagnostic distance.
Brad Sewell is offline   Reply With Quote
Old 01-26-2013   #14
Hib Halverson
Hell with diagnosing my LTPWS. I want some "Wazoo Ice Cream"!!
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
