08-16-2014 | #11 |
Re: Clutch Disengaging issues
I checked it before and again last night....looks to be fine
08-17-2014 | #12 | |
08-17-2014 | #13 |
must be a trend... I had the same symptoms with mine. Still not sure what caused it. Rebuilt slave & master, no change. Took it all apart, and there is no obvious damage to the clutch or PP. Guess I need to take a closer look at the fork & pedal.
Not sure what to do next. I am going to put the RAM dual disc in it when I put it back together. More engine work to do first |
08-17-2014 | #14 | |
If any ZR should have the dual clutch it's yours.
08-17-2014 | #15 |
At a minimum I wish I had added a hydraulic throwout
08-17-2014 | #16 |
Um yeah... 'cept the stock Valeo is a pull type pressure plate, and the RAM (far as I know) is a push type hydraulic throwout type; but I hear ya.
08-17-2014 | #17 |
Time to move on boys & girls .
Stock Valeo pull type pressure plate and slave cylinder setup is nothing but a valley of tears experience.
Phil Wasinger 1994 Torch Red ZR-1 WAZOO Member George Braml Intake Last edited by Jagdpanzer; 08-17-2014 at 03:11 PM. |
08-17-2014 | #18 |
Not trying to hijack this thread, but based on the posts, thought it might be of interest to the participants. If anyone thinks it's not appropriate, just say so & I will delete it.
FWIW, if you are considering a RAM Dual Disc Clutch, we have just marked them down.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 08-17-2014 at 01:57 PM. |
08-17-2014 | #19 |
You are correct.
08-17-2014 | #20 |
So today, not as bad.....hmmm.
